A week ago, I received 2 packs of the amazing Sony 3800mAh AA NiMH cells:
I actually didn't believe someone could make an AA NiMH cell with 3800mAh capacity, so I put the CBA II to good use:
Discharge at 1A suggests cell capacities of 560mAh, 530mAh, 520mAh and 570mAh, an average of 550mAh only.
I attempt discharge at a lower current (50mA = C/14), as I suspect these super-high capacity cells have an issue with higher currents. Well, it brought the capacity up to an average of 650mAh, not anywhere near 3800mAh:
Another strange thing I noticed: Cell number 4 did not charge properly on my Ansmann Energy16 charger, neither did it on a TCM cheapy. The chargers ended the charge far to early and the cell appeared to have a very low capacity. So I trickle-charged all cells at 50mA from the bench power supply, only then they exhibit the performance shown in the first graph.
What's going on ? Are these fake cells ? Anyone come across these ?
Editing to add some numbers:
These cells are very lightweight. Comparison of cell weight:
4 pcs AA Sony CycleEnergy 3800 = 67g
4 pcs AA Sanyo standard 2100 = 113g
4 pcs AA Sanyo "Eneloop" 2000 = 105g
4 pcs AA Varta "Ready2Use" 2100 = 113g
These cells are relatively small by their dimensions:
Sony CycleEnergy 3800: Length = 49.7mm, diameter = 14.0mm
Sanyo standard 2000: Lenght = 50.4mm, diameter = 14.2mm
Sanyo "Eneloop" 2000: Length = 50.3mm, diameter = 14.2mm
Varta "Ready2Use" 2100: Length = 50.5mm, diameter = 14.3mm
