Copied replies:
jeffb08-09-2007 06:11 PM
Re: SPY Upgrade thread.
This is the list for "upgrading" SPY 005 (apparently I cannot edit post #2) Please indicate your intent in this thread or PM me!
( ) indicates number of Spy 005's to be upgraded (Thanks "fasteddie"!)
jeffb (1)
Turd_Ferguson(1)
fasteddie(2)
LowWorm(1)
LouRoy(3)
LED Zeppelin(1)
Rudi(1)
Christoph(1)
kiessling(1)
Brightnorm(3)
alanhuth(1)
ArsMachina(1)
peterb(2 SELF_INSTALL*)
Roboholic(1)
Turd_Ferguson08-09-2007 07:41 PM
Oh heavenly day! Woo hoo!
Eagerly waiting instructions.
fasteddie08-09-2007 08:06 PM
I've got two that are waiting to be upgraded. Waiting for your instructions.
dat2zip08-09-2007 08:15 PM
jeffb, I would be happy to have you moderate the list. Please update post 2 and feel free to put your name #1.
When I get the process down on upgrading the light I won't be able to handle more than about two lights at a time. I don't have room in the garage to put these on a shelf with a tag with your name and keep track of who's who. Also, I will doing this between my other projects so, I'm sure CPF'ers will be able to overwhelm me faster than I can do the upgrades
I will see what catches on fire this weekend and if there is no smoke I will post an update early next week on how well I did and whether or not I need to consult the SPY guru. Hopefully, the guru will be in this weekend for consultation!
The basic process will be similar to this. I will post to this thread which lights I have just completed and list the next name(s) on the list that will need to send their lights in. I will need those I name to acknowledge in this thread only when they have put the light in the mail.
We need to work out the logistics of what mail the lights will be coming and going and what service I will use (USPS, UPS, Fedex). I'm thinking that with this project it might be best to use Fedex since there will be tracking on the shipment. Anyway, I'm still brainstorming... Any thoughts, suggestions will be greatly appreciated and you are more than welcome to chime in. Maybe, I should start a separate thread on the logistics and keep this thread only on the active list and which ones are being worked on.
Wayne
Data08-09-2007 08:18 PM
The reflector is replaced with one modded for the Seoul LED. It has a pocket machined in it to center the emitter.
Also, there is an option to upgrade the battery cap spring. I do know the cost of that option is going to be $15. The replacement spring does not work any better then the old one. It is simply a cosmetic upgrade to the inside of the battery cap. I had the springs made in a custom run just for my lights. The old spring was made of two springs soldered together. The new one is a single piece of silver coated spring wire.
Cheers
Dave
Trashman08-09-2007 09:57 PM
Cost?
dat2zip08-09-2007 11:15 PM
Quote:
Originally Posted by
Trashman (Post 2052911)
Cost?
I won't know the costs till I get a good handle on the what it will take me to actually do the upgrade.
I can only give a range at the moment. I don't think I'll even post the range till I do some testing of the procedure this weekend. Next week I'll have more details.
Wayne
brightnorm08-10-2007 12:17 AM
I have three SPY005's waiting for upgrade. One was recently Seoul-mated by Scott, but kept the old board. It is lovely but I find the beam a bit too dispersed for my taste. Is that unavoidable with the Seoulmated SPYs or is the degree of disperson/focus adjustable. Will you do any Cree or Rebel mods?
Brightnorm
Tritium08-10-2007 05:46 AM
Does the owner retain the removed parts or do you?
Thurmond
Data08-10-2007 08:12 AM
brightnorm, the beam pattern after we do the upgrade will be just as tight as the original chrome 005 pattern was with the Lux and McR18. The only difference is the light output will be way up over the Lux. In fact, after the upgrade the Seoul is brighter on level 5 than the Lux was on 6.
I did not supply Wayne with any parts to offer other emitter options. The Cree does work well in the 005 but I decided in order to keep costs down we would only offer one option.
Tritium, the leftover parts are not returned with the light. We reuse the contacts and switch from the old DB converter board. To get the switch off of it renders the board unusable. The heat sink and old Lux emitter are not returned either.
Cheers
Dave
cave dave08-10-2007 03:08 PM
Can I buy a new reflector and heatsink and do the mod myself? I'm happy with the old driver board.
Data08-10-2007 04:32 PM
cave dave (Post 2053157)
A few people already have upgraded their LED to a Seoul. It requires some tools and modding skill but it can be done. Milky does it as a service.
If you take the light apart you will be voiding the warranty. The delicate thing there is the switch and knob interface. It must be treated with care.
One down side is the low power setting will be brighter than it was before. You can't turn it down farther than it is. Also, the new converter board is state of the art and superior to the old DB in every way.
Cheers
Dave
ArsMachina08-10-2007 04:44 PM
Hi,
nearly same question as above....
I would like to upgrade my SPY, but I am not willing to ship the light over the pond again twice.
The risk of loss is too high, insured shipping from Germany is horrible expensive and finally I will have to pay taxes for the insured value of the complete light when it comes back to Germany after being upgraded.
So I would prefer buying all the parts and doing the upgrade myself - even I will loose my warranty.
I already modded the old board with a P4 so I believe I will also be able to change the board
Jochen
LowWorm08-10-2007 10:18 PM
Me, I want in on the upgrade.
Thanks Wayne and Dave for making this an option. :twothumbs
cave dave08-11-2007 10:14 AM
First off, what warranty? The light was only warrantied for a year.
2nd. If I screw up I can send it in and get the complete upgrade with new driver board and everything so unless I break the actual switch or body I have nothing to lose by trying.
3rd. I thought their was a pot somewhere on the board for level 1 and 2? Can't I turn it down?
Data08-11-2007 11:47 AM
cave dave
Yours may not be under warranty but the newest lights still are. Still, I try to fix anything I can for people if they have not caused problems by modding the light themselves. You should see some of the stuff I have seen.
As you said, "unless I break the actual switch or body I have nothing to lose by trying". This is true.
No, you can not turn it down. Level one on the DB is already down as far as it will go. It may work if you do not adjust it but the Seoul will burn brighter. The DB was made for the Lux, I have not tested it myself on the Seoul. When the Seoul emitters came out I was already using the STFu.
Dave, you are welcome to mod your light, I mod everything I get too.
But, the STFu is a marvelous board and way more capable than the old DB. Just as an example of its most basic function, the programming that controls the power change from one level to the next is very sophisticated and provides a very rapid yet smooth transition of lumen output. There are VERY few uP controlled lights in the world with this level of quality. Wayne and I set our sights pretty high with the STFu board and I dare say he hit the mark. Yes I know to some degree, I am blowing my own horn, but if you knew all that we put into the STFu you would be pretty proud of it too.
Cheers
Data08-11-2007 11:50 AM
ArsMachina (Post 2053206)
Hi,
Jochen
We are talking this over and I will reply back later. One thing I can tell you for sure is, you would have to send us your old DB board so we could get the switch off of it.
EDIT: Wayne is telling me he will offer the kit to people that want to do it themselves. Keep in mind, the cost of the kit will be about the same if Wayne does it or if you do it. If I lived in the states I would definitely send the light to Wayne. On the other hand, if I lived over seas, I am not sure...
Cheers
Dave
cave dave08-11-2007 12:17 PM
Data (Post 2053475)
Cheers
Agreed from experience, as I own both an old one and a new one!
Data08-11-2007 02:13 PM
Dave
Well, I tried my best to talk you into upgrading the converter.
:nana:
I saw that picture before, but I never noticed the o-rings. They really help keeping that sharp edge from getting chipped if you have something in your pocket with the light.
Are your o-rings staying in good?
Cheers
Dave
cave dave08-11-2007 07:44 PM
Data (Post 2053514)
Dave,
...Are your o-rings staying in good?
Cheers
Dave
You bet! I think it really improves the feel of the light. I've thought about adding a bit of glue because sometimes, not very often they fall out. If the grove was cut with a spherical bit with an undercut I bet they wouldn't come out.
LED Zeppelin08-12-2007 11:12 PM
Please put me on the list, thanks!
Rudi08-13-2007 03:17 AM
Please add me to the list.
Thanks.
Christoph08-13-2007 01:11 PM
Put me on the list please
C
jeffb08-13-2007 03:33 PM
List updated!!
jeffb
Kiessling08-13-2007 05:35 PM
Count me in for the upgrade, too !!!
SPY005 #13
uninsured intl. if possible (I take the full risks)
bernie
fasteddie08-13-2007 08:59 PM
What's the number in parentheses in the list for? If its the number of units to upgrade, mine should read 2.
Tritium08-14-2007 06:05 AM
I'll make a decision when I know the cost and time frame.
Thurmond
jeffb08-14-2007 06:09 AM
fasteddie,
changed list to show (2) units and added a description for units!
Thanks for your input!
jeffb
brightnorm08-14-2007 07:48 PM
Please count me in for 3 upgrades.
Brightnorm
alanhuth08-15-2007 08:09 AM
Please put me in for one upgrade.
Thanks,
alanhuth
ArsMachina08-15-2007 12:18 PM
I am in for one upgrade.
Jochen
PeterB08-15-2007 12:46 PM
I'm in for two (self installed) upgrades. (I don't wan't to risk a loss during shipping from/to germany)
tanasit08-15-2007 06:54 PM
Ditto
Tritium (Post 2054570)
Thurmond
Turd_Ferguson08-16-2007 06:32 AM
USWOI
Any mail option is fine. The most convenient for the shoppe is my preference.
cave dave08-16-2007 04:08 PM
Is the switch really so expensive its worth recycling? Maybe for the overseas folks a whole new board and switch at and additional cost. It would always be nice to have complete and intact spare internals just in case.
Data08-16-2007 05:07 PM
cave dave (Post 2055394)
We are going to require the DB boards back so we can get the switch off the old board. If you are not going to send your light to Wayne you will have to take the old DB board out of it and send it to him so he can build up the new converter and send that full kit back to you.
This upgrade service Wayne is offering is not simple. There are many things to be done and many parts and fixtures Wayne and I have readied. We are doing what we can to keep the costs down. When the STFu was completed I knew I would want to offer this to everybody with the old chrome 005 lights. Logistically this has been a challenge.
I am glad it is about ready to start. Wayne has worked through the conversion on his old prototype 005. It took him 2 hours but he said it would go much faster in subsequent builds.
It will not be long now.
Cheers
Dave
Roboholic08-18-2007 07:17 PM
Did I miss the cost?
Thanks Rob
