SSC P7/ Cree MC-E Buck Converter ( New Version)
Seoul P7 / Cree MC-E Buck Converter
more detailed information:
Full Datasheet
the specs:
Current Regulator:
- Output Current: 2.8A
- Min. Input Voltage: 4.2V or Vf of LED. ( changes to direct drive if the input voltage is too low. Driver shuts off under 4.2V)
- Max. Input Voltage: 20V
- up to 4 LEDs
- Diameter: 25mm
- Height: about 11mm
Connection:
Vin: positive Input
GND: negative Input
L+: positive Output ( anode of the LED)
L-: negative Output ( cathode of the LED)
Driver Versions:
Single Mode: Only 100%
Version A (4-mode): 100%; 70%; 25%; 3%
Version B (6-mode): 100%; 70%; 25%; 3%; Fade in & Fade out; Strobe
Version A/B Driver needs a momentary switch which must be connected to "S3" and GND.
[Click here]
Version B Driver in action:
http://www.youtube.com/watch?v=FOuQortrgUY
Fits in D and C Cell Mag-Lites.
Price:
Single Mode : 20 Euro
Version A (4-mode): 25 Euro
Version B (6-mode): 25 Euro
Germany: 2.20€
International: 3.45€
For registered mail please add 2.15€. If something gets lost with registered mail, I'll refund the money or send the ordered parts again.
If you want one please pm me or contact me via email
This component is for expierienced user only, so please inform yourself before ordering.
I can't replace defective components. Sure is that all drivers are being tested before shipping.
Here is the original Thread:
http://www.candlepowerforums.com/vb/showthread.php?t=199533
Thanks
Update 2.1.2010:
Unfortunately Deutsche Post has rised up the shipping cost within Europe to 3.40€.
I really don't understand why they are doing this since this would be nearly twice as much as other European countries.... :thumbsdow
Update 28.10.2009:
Since I got some feedback in the past about difficulties in soldering the cables to the LED, I changed those to silicon cables which are more heat resistant and more flexible and therefore easier to solder.
Update 19.10.2009:
- Driver with modes are available
Update 14.08.2009:
- New Drivers available: Smaller, Higher Efficiency, Constant Current
UPDATE 5.1.09
Shipping costs changed to 3€ for europe and 6€ for the rest of the world
UPDATE 9.09.08:
Drivers and dimmers (9€) are available now.
UPDATE 18.08.08:
First batch are all sold.
The next batch will be finished in two weeks.
Furthermore I will offer two versions because I got some replys that setting the voltage is not that easy.
First version will be the version as before with a voltage range up to 10.5V.
For all those who wants to drive one emitter the second version is better suited which has a voltage range up to 4.2V.
Update 7.10.08:
sry but currently no more driver boards are available.
The drivers will be available in one week or so if I can handle the new bigger solder iron for soldering smd parts.
The dimmers are out as well ....
Update 26.10.2008:
Drivers are available again
