SSC P7 C-Bin LED with 21mm Base @ DX
I wonder what material the base is made off? Looks a bit like aluminium, but they dont clearly state it...
Based on the other emitters that I purchased from them I am quite sure that it is. I wonder why they did not use a star as the size is almost the same.
I saw this also on DX... Looks like a very good price if it really is a true "C" bin. Cheaper than everywhere else by ~$5+
@ CampingLED
Stars are usually made out of very thin aluminium. I believe the base on this one is a bit thicker, so better for heat spreading...
i bought bare stars for P7 from KD and yes they are thicker then you normal Cree/SSC stars...
Time will tell if it a true C-bin. I do not think they will make the same mistake twice in a row since the bare emitter was originally advertised as a 900 lumen and later changed with a correction.
I would tend to agree that it is mostly likely a true C-bin. Almost as important is to know what the tint and vf are. The other P7 on DX is SYP tint which is the bluest of the bins ... 8000 - 10000 K :thumbsdow
10 dollars!! That would be GREAT! :twothumbs
So my friend is thinking about using these P7 leds in his car as reverse lights.
However, I haven't been able to find him a suitable driver for it anywhere. I know KD offers a driver for the P7, but the input range is far below the 12+ volts a car would put out.
Any takers on helping a LED newbie on what to drive these P7's with in a car or how to do it?
Any help is much appreciated.
The easiest is to use in-line series resistors. You could either use the two P7's in series with one resistor or use them in parallel with a resistor per P7 (recommended as the wiring of the car should support this option better). To assist with the calculations of the resistors, you can see here. Use a value of 13.5V or 13.8V for the car battery with alternator running.
Resistors will waste far too much power to be useful. Instead, 4 DX sku.6090 modules with no reflectors will be more efficient off of automotive 14V.
Thanks for the info! Would I link sku.6090 in a series and then hook up my two P7s in series with it?
Also, it would be a big waste in reflectors, is there a place I can just get the drivers without the extras?
Sku.6090 is a board and Cree P4 emitter mounted to a brass threaded module. You wouldn't need any P7s.
If you're dead-set on P7s, then Kaidomain sells just a board that puts out 700mA from automotive power. This one. I'd wire 3 of those in parallel and the 2 P7s in series off of that.
Thanks LukeA.
I'll pass along the information and I'll let you know how it went upon completion!
:twothumbs
Has anyone removed the emitter off of the base without damaging it? If so, how?
if its a cree emitter i dont recommend your removing that...its the second hardest LED i had to solder bare. the first is Rebel....
i used some pilers to hold the star board and used a hand torch and after a few seconds the emitter slide right off. i dont recommend ripping it off. those things are fragile...
my dad likes to use a car battery for a lot of stuff, can i use this 6090 module directly fed from a car battery?, would heat be a problem if its used like a bulb hanging from a ceiling without it being attached to anything?
also i found this: http://www.dealextreme.com/details.dx/sku.11836 would it serve the same purpose?
