LEDobsession
Hey I was just courious, how do you tell the anode and cathode apart on the P7 emitter? I'm sure it has something to do with the small small hole on one side of the leads but which is positive and which is negative?
The small hole is on the cathode (negative) side.
The slug is also positive so keep that is mind when mounting so it doesn't make contact with a bare heatsink that may be negative.
That will still work, the thermal epoxy will insolate the electrical connection. I would use AA (arctic alumima) for mounting.I figured that would be the negative side.
Crap. I was going to mount the LEDs to the heatsink using thermal epoxy and ground everything to the heatsink. I guess that wont work.
Thanks for the info!
Is there some reason you're not using the MCPCB designed for it?
I figured the best chances for a low thermal resistance would be to take some fiberglass boat cloth, unweave a bit, and separate out a couple single glass threads. Tape (or superglue) on one side of the sink's mounting area, pull across the mounting area tight, and tape/glue to the other side. So like you'd have 1/4 the pad area to the left of one thread, 1/2rd between the threads, and 1/4 to the right. Then you should be able to mount the LED and apply pressure and still guarantee a minimal spacing without a lot of extra spacing. In theory, at least. But it's still gonna be thicker than the very thin layers they recommend.
Contact the Arctic company and ask for their recommendations. They know their stuff pretty darn well.
