big beam
Has anyone come out with one of these.With less heat it should be a natural.
DON
DON
PhantomPhoton said:SSC = Seoul Semiconductor (P4 U bin 🙂 )
Doubtful these will be any good if someone were to make them due to heatsinking issues though.
cratz2 said:But... but... The SSCs and Crees seem to put out less heat than Luxes. MUCH less than the K2s. And if a manufacturer would drop the current down to a reasonable level to get usable brightness and great runtime, then that will help with the heat issue even more.
Personally, I think a Mag 2C with an SSC or Cree emitter putting out about 20 lumens would be pretty darned handy. A bit brighter than the SMJLED PR, but with less heat and more neutral color.
Inherently the difference in heat isn't going to be much at the same power -- the Seouls convert about ~75-80% of the electricity to heat, as opposed to 85-90% like in the older LEDs. On the other hand, with incandescent almost all of the energy is radiated, but only a small portion of it is visible.But... but... The SSCs and Crees seem to put out less heat than Luxes. MUCH less than the K2s. And if a manufacturer would drop the current down to a reasonable level to get usable brightness and great runtime, then that will help with the heat issue even more.
Burgess said:Like you, i would really love to see a LOW-POWER version,
which would provide about 20 Lumens with a LONG-RUNTIME.
