etc
I have a couple of 2x18500 lites with Malkoff, as well as 2x18650 bodies.
Recently I saw a Surefire 6P body bored out to take 1x18650. That's neat as it would be compatible cell-wise with the bigger Leef 2x18650 unit. Then I would only worry about 18650 cells without having to deal with both 18500 and 18650 cells. Then 18500 cells could be cut out entirely, as I wouldn't need them.
Plus 1x18650 should be more EDC-able. The current 18650 from AW is rated at 2200 mAh but I hear there is a 2500 mAh version coming. While 2x18500 combined are 3,000 mAh. So there is a drop, but how much is runtime affected?
Also I presume that a 6P bored out to take 1x18650 would have to have Malkoff M30, due to low voltage.
So my goal is to have 2 18650-based lites:
1. Leef 2x18650 with M60 for serious work and better runtime, especially loaded with 2500 mAh cells, for pretty decent runtime.
2. For EDC, 6P bored out to take 1x18650. It would have to have M30 in it. Only problem is, I couldn't use primaries in it. But it would be compact. I hear 2 hours of runtime.
