GreenArcher
Hello all,
I am new to the forum and recently bought several flashlights. Two of them are the SF G2 Yellow and SF E2E-HA. After playing with the two lights, it is really annoying me now that I have to put extra pressure on the tail-switch of the E2E to keep it momentarily lit. I can barely use my pointing finger and thumb to sustain the pressure for more than 3 seconds without the lit flickering (too much work to maintain the pressure). It seems to be a lot more tiring the the G2 switch. Is this normal?
The SF G2 that I have requires very little pressure to light up. A tap on the tail switch is enough for it. The required pressure can easily be maintain by my pointing finger, more so with my thumb.
I would estimate that the E2E requires at least 5x more pressure than the G2 to maintain the momentary on. I have to use the lower part of my thumb instead of the pad to apply the pressure. However, the E2E tail switch is at least 3x easier to rotate.
Btw, I made sure that the switch is rotated enough to almost engaged the light to ON when comparing both. I noticed that this affects how much pressure is required.
Ian
Ian
