KevinL
I've got a 3 year old U2 from one of the very first lights produced and it is an AWESOME light.. it still is
However I think the years are getting to it. The selector dial is now so stiff it requires two hands, with almost as much force as it takes to get a stubborn bottle cap off a bottle. I'm quite sure this was NOT part of the original design specification.
Early adopters had one trick which was to 'soak' Nyogel or similar lubricant into the light while rotating the dial back and forth. It's worked for me before, but no longer seems to work.
How much force does it take to set the power level on later U2s? And has anybody figured out a way to disassemble the U2 to fix the dial?
Before you say 'send it in' I'm genuinely concerned about losing this particular special U2 with one of the nicest tints I've ever seen on ANY LED emitter (it's a WA tint according to LuxV bin codes and pink), and it's also one of the 'old' U2's with 18650 support.
Come on PK, give us back 18650 support.. you da man!! Don't let the diehard U2 supporters down
PS: Where's our L4 with U2-style collar?
