Hello All, First forgive me if this is in the wrong section, there are so many to chose from I hope this is the one.
I have a stream light scorpion that is atleast 16 years old but closer to 18. It looks brand new as I only used it until the first set of batteries went down which wasn't long. I went to Walmart for two more and they were over $12 so the light was put aside and hasn't been used since.
a couple of weeks ago I ordered a Cr123a charger and four batteries to but the light back in business. After charging I installed the batteries and nothing, then I noticed the bulb had fallen out inside the cap and was flopping around. So I got a screwdriver and drove the lens off after attempting to remove the lens by prying it off.
I scratched the lens with the screwdriver but got it off and retrieved the bulb. I put it back in and it immediately fell back out prior to installing the lens. I bent the legs a little hoping to help hold it in but that did not happen, after putting the cap on it fell back inside the cap in 2 seconds while I was trying to get it to come on. So this time I pulled it back thru the hole with tweezers and bent the legs again but you have to bend them back to get them into the socket holes.
So I got out the new one and installed it but same situation bulb will fall out if you point the end towards the ground.
I got wise and put a very small drop of super glue on the bulb bottom and left it overnight. It is staying in but I don't know how much of a bump and it's out. I tried to get it to come on but no cigar.
I am hoping someone can help me troubleshoot it and get it going again now that I have rechargeable batts and charger maybe I can keep a light that will work. I did not check the bulbs for continuity just assuming the new one would be good being it's never been used. I can't even figure out for certain which way the batts install but tried them both ways with 4 different batts and two bulbs one new one used ever how long a set of batts lasted about 20 minutes if I remember correctly.
Does anyone have any suggestions on what to do next? I have 6 different stream lights all over 15 years old as I became disabled in 2005 and that ended my daily need for light. I got my polystinger and the stinger with the big head going but am disappointed in their performance after using Chinese led flashlights so I know the scorpion is very bright and would like to get it up if no more money has to be spent. Sorry for rambling just need help troubleshooting the scorpion.
thanks
thanks
