so, if i'm reading this right, streamlight is comepletely and totally full of poop in their 336 hour runtime claim. Had i been aware of this, i wouldn't have purchased two of them. I want my money back.:mecry:
Here is a runtime I did a few weeks ago.
I use a lightbox similar to Flashlight Reviews.com - data logging 10 min intervals - light intensity is the raw lightmeter readings ExTech 401036
mb
Unregulated (direct drive) lights show a rapid drop at the beginning if you put in a battery fresh off the charger. But most often, I've found that a big drop in the first couple of minutes is due to poor heat sinking. LEDs put out considerably less light if they're running very hot. See here for an example.Yes many lights have outputs that drop like a rock the first 2 or 5 min.
Alternate 50% Points
4680 (85% of peak)/2 = = 2340 (43% of peak) = = 8 hrs
( 4860 is about 1 min into run )
3500 (64% of peak)/2 = = 1750 (32% of peak) = = 17 hrs
( 3500 is about 40 min into run )
5490 was the startup peak
Use which ever one works for your application.
mb
Oh, come on mike, "reasonable brightness at 48 hours" ?? Gimme a break, they went out of their way to imply HUGE runtime. Of course, i didn't expect PEAK brightness for two weeks, but more than enough light to clip my toe nails by after a few hours isn't expecting a lot from a manufacturer claim of 336 hours.Again, if the graph is accurate, i can expect roughly only a quarter of initial brightness after a mere 24 hours. For a light that's marketed as having 336 hours of usefull light, this is unacceptable bullshit, especially considering this is a company with a long established reputation.
