Streamlight PolyTac Review, Pics, and Info
RobertM
United States
Streamlight PolyTac
So I was browsing a local brick-and-mortar store that carries a variety of higher-end flashlights (SureFire, Streamlight, Princeton Tec, etc.) and came across this new Streamlight PolyTac. What caught my attention and prompted a purchase what the fact that is has a focusable beam.
I’ve been using it most of the week so far and overall I must say that I like it. The light output seems to be pretty close to that of a SureFire P60 lamp, it is almost identical in size to a SureFire G2, has a polymer body, runs on 2xCR123 cells, and features a forward clicky tailcap.
The PolyTac has a nice feel to it and provides a good amount of grip with its tailcap that is slightly wider than the body. The Xenon beam is fairly white and very round. When the bezel untwists which widens the beam to a flood focus. In the tightest focus, the beam is pretty flawless but some artifacts are present when using the flood beam focus.
SureFire G2 Comparison:
- Overall, the G2 feels like it is the better built light. The Nitrolon provides for a better feel than the polymer used on the PolyTac as well.
- Both lights are 2xCR123, both with similar output and runtime, are pretty equal in price, and both would be great cold-weather-use candidates.
- The PolyTac’s clicky tailcap is a nice touch over the G2’s momentary/twist-for-constanst tailcap (if a clicky is what one wants). With that being said, the PolyTac’s clicky tailcap doesn’t feel as good as other SureFire clickies I’ve used.
Pros:
- Bright, round, clean beam
- Focusable spot-to-flood beam
- Bi-pin bulb socket provides for other bulb and rechargeable options
- Glass lens
- Forward clicky
Cons:
- Nowhere to attach a lanyard
- Tightest beam is less focused than the pre-focused beam of a SF P60
Conclusion:
It would seem apparent to me that if one is looking at the PolyTac for purchase, he or she will likely cross-shop it with the SureFire G2. One really can’t go wrong with either light; it just comes down to preferred features. If the option of using other bi-pins lamps, a focusable beam, and a clicky tailcap on a quality polymer light are desirable features, the PolyTac would be the choice over the G2.
-Robert
Very nice review and good pictures.
It appears that the polytac is priced around the same as a Surefire G2 and has a lot of features for the price.
I noticed that the Polytac will not accept standard D26 incan or LED dropin lamp assembly's. However, it's bi-pin bulb is the same as the TL-2 and will probably cost under $$7-$10 to replace.
Although sometimes useful, I was never really fond of my incan's TL-3's focus feature. The red rubber grommet in the reflector that the bulb fits through seemed to pull the bi-pin lamp out on more than one occasion, sometimes causing it to fall out between the reflector and lens.
I realize that some people may have a specific use for such an incandescent light but flashlight offerings such as both the incan G2 and incan Polytac seem so outdated to me now in output and efficiency compared to the newest LED offerings.
Seems nice to me, you could pop some imrs and one of those custom carley bulbs in there (1749?) and have a nice, bright, focus on the fly hotwire, assuming the tailcap will hold up to the current. If it does this could be one of the best bang for the buck incan mods out there.
Man, now I want one of these.
Looks a very good competitor to the SF G2, with more features and flexibility.
Moving this to the Reviews section.
RobertM
Tightest beam is less focused that the pre-focused beam of a SF P60
ha! I thought that was kind of funny for some reason.
Hey, it looks solid and the bi-pin deal is pretty cool. Good job Streamlight.
Thanks for the review. :)
Nice review and Pics...Thanks! I saw that BG had the led version...less than $40...might pick one up now that you have shown that the light looks decent. Thanks again for the review.
I noticed that the Polytac will not accept standard D26 incan or LED dropin lamp assembly's. .
So no malkoff's drop-in? :mecry:
I love the shape of this light and was hoping to use it as a host for a M60LW.
Nice review, Robertm.
I purchased the LED model a few weeks ago and have been using it almost daily for everything from work to fishing and some very long walks through the swamps in the area. I have given it out as a loaner light and almost everyone that has used it has been impressed. The output looks like an honest 120 lumens, perhaps a bit brighter than my U2 and a bit dimmer than my KL4A and E2DL heads.
I've been impressed so far and have purchased two more for loaners and backup lights. Only time will tell how well it holds up but I think Streamlight got it right this time.
Is it just me... OR does this new Streamlight remind anyone of the old Brinkmann Maxfire LX's a little? :thinking:
You could do a lot of things with this one. Bi-pin options are great to have.
What kind of mods could you do if you want to run rechargeables?
Not necesarilly looking for brighter, just run time & guilt free by saving $ from primaries
Well, like any light designed to run on a pair of CR123 primaries; the easiest option is to run a pair of unprotected 3.0 RCR123 rechargeables.
