<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by kogatana:
posted by Herky:
[qb]But I also need some long throw as I light up down alley ways from the entrance of them.
<HR></BLOCKQUOTE>
Pardon the unabashed endorsement, but the ASP Triad can meet this requirement.
Somebody will likely "chime in" with a different opinion about Surefire Turbohead light carry. How many of you carry 15-16 (sometimes more) hours a day like I do?
BTW, the tight focus ability of the ASP Triad allows long throw without the larger reflector (Turbohead).[/QB]
__________________________________________________________________________________________
Herky,
My experience with the ASP Triad is identical to Kogatana's.
The Scorpion is an excellent light for the money. Nevertheless, I gave away both of mine to friends, mainly for two reasons:
1) At tightest focus the beam was a bit too diffuse for my taste, and therefore "dimmer" than the Surefire P60.
2) I actually found that the ability to focus was a liability. If you need to quickly/unpredictably present the light, you can never be 100% sure of its focus setting, since it is so easily disturbed by contact.
Regardless of advertising, the optimum focus for any given lamp/relector combination is usually very restricted, which is why the SF lamp/relectors are integrated and preset. The E2 is an exception to this, but if you examine it carefully, you will see that it achieves the equivalent through other means. Also, whenever you change the Scorpion's batteries or lamps you disturb the focus.
The Asp Triad has a unique internal set-and-forget focus mechanism, which I find the best compromise, though frankly I'd prefer a fixed, prefocused arrangement like the Surefires.
The three lights I own with the best external focus design are the US, because it retains focus quite well and is "bottom loading" so battery change doesnn't disturb focus; The Surge (despite the fact that it is "top loading, because it retains focus settings under most normal conditions.) And, surprisingly, the LX. Even though it is top loading and retains focus moderately well, it presents a very decent beam throughout a variety of focus settings. This is unusual.
Let me say again, I am not knocking the Scorpion; it is an excellent light for the
money, but it simply doesn't meet my requirements.
Brightnorm
