So for my first serious mod I'm looking to take a Streamlight Sidewinder and modify it to better fit my needs. Basically, I'm happy with the concept of the light, but I need more than the weak output on Red and the Twist/Push UI doesn't really do much for me. The White LED is also not particularly efficient and because of the way that the board is set up it's not easy to do a LED swap.
So here is my plan:
Pull out all the guts, including the driver and switch, and replace the switch with a sealed rotary.
I plan to use a Cree XP-G and an XP-C Red (each with 10mm optics and holders and 350mA micropuck drivers) and three 5mm LEDs with resistors to give me five selectable modes:
5mm IR, 5mm Red (Low), 350mA XP-C Red (High), 5mm White (Low), and 350mA XP-G white (High).
I'm hoping to get around 60-70 lumens of white light and 40ish lumens of red on high, with the 5mm settings outputting just enough to read by.
My major problem is that I have minimal experience with electronics, and while I do know how to solder and should be able to handle the fabrication parts of the build, I'm not sure if the way I'm going about designing things is sensible or efficient. I'd like to follow a KISS philosophy, and minimize chances of breakage or points of failure.
Here's my plan for wiring:
and here's my plan for the modded front of the light (approximately to scale):
The light runs off 2xAA batteries, and I plan to keep it that way.
My questions are: Is this the best/right way to wire the light?
And, how do I run a 5mm White led off 3v? Do I need a boost driver for that too? I know I have a resistor in the diagram but that's wrong, no?
Comments and suggestions appreciated.
So here is my plan:
