Sub 3" folded options?
Surnia
Ontario, Canada
Just started looking into knives after picking up a small 2.875" (folded) Black ceramic folder from a guy named Phil Cressman, and I'm finding I have a higher preference to straighter blades.
What do you guys think of the CRKT H.U.G. II? I know the steel's not that great (420J2), but I have to insist on a knife that's smaller than 3" folded, with a Wharncliffe/leaf blade. The H.U.G. II so far has been the only one that fits the two parameters.
Thanks for your help!
*edit*
title was edited to reflect other options...
Current list is:
AG Russell 3.0 Titanium lockback
Boker Wharcom
Spyderco Spin
Re: CRKT H.U.G. II Opinions?
I am not a fan of single-sided knives like this one. I find them weak and not trustworthy (eg: easy to fold up on you accidentally).
I would recommend you consider the Boker Wharcom instead, which is a very well-received small folder.
I have several of the small electrician/utility (E.O.D) white ceramic knives from Phil and they are AWESOME. He is also very good to work with and easy to communicate with :D
I had not noticed the Boker Wharcom, thanks carrot! Any opinions on the AG Russell titanium lockbacks as well? bit more belly, but looks pretty good as well. VG-10 blade too, vs the Wharcom's 440C.
I agree, very easy to communicate with! I was debating over the EOD and the GP-1 for the kitchen, and we settled for the GP-1. Excellent for its size, although the GP-1 is rounded up front a bit.
Actually, due to a small mixup in my initial order, I end up with both the EOD and the GP-1 (I bought like 4-5 of them). I like them both for different reasons - just purely subjective, depending on what I am doing.
Will
If you are referring to the A.G. 2.5" titanium lockback I'd say pass. They are nicely made and have excellent steel but are so small I'd use it as a keychain knife only. I would keep it to open packages on my keys and definitely not loose in my pocket.
Come to think of it you may also like the Spyderco Kiwi, but I don't remember if the new stainless handled one came out yet.
Actually I was more referring to the 3.0", they seem to have some defect ones that are selling at $26 right now.
Kiwi looked great, but its a little high on the price point..
*edit*
finding a lot of wharncliffes, but the good steels all are discontinued.... Spyderco Spin looks good, wonder if I can find one...
*second edit* I found a Spyderco Spin for $40 CDN, I'm very tempted to grab that.
Have you seen the Kershaw Onion/Centofante (model 1610)? It's discontinued but they're still out there. It's a little bit bigger than your requirements at 3.125" folded but it's a great little linerlock. I bought mine cheap, though I could not find a black one so I ended up with a dark red one.
The Spyderco Kiwi is absolutely superb. Sure it's a little pricey, but it's a nice small VG-10 Wharncliffe blade, with bone scales on a stainless body. Very classy, and hella sharp :D
The spin looks nice, but not owning one, I can't really comment.
I like the Spin but I found it a bit on the small side for my tastes. Despite the small size it is very easy to handle and easy to control, so it is still one of my favorite small blades. Unfortunately I seem to have misplaced it lately, and I miss it. I like the Cricket a good deal more thanks to its slightly larger size and wicked reverse-S blade, making it an excellent all-around knife for many tasks except food prep.
Interesting blade, fits a lot of my needs, thanks! I'll keep it in mind.
I agree it look great and does pretty much all I'd want a blade to, but its been discontinued and its hard to find one now (let alone the price >.<)
The reverse S is quite interesting and I've been eying the cricket as well... My question is, how do you sharpen that thing? edge maintenance is my only worry with that kind of shape...
I really don't think the size will be an issue, considering my current knife is this:
and I mainly use it like this:
If you can live with being just a tad over 3 inches closed, the Case swayback jack (or gent) is a great little wharncliffe, but 3 it's 1/5 closed. They also make a 2 3/8 inch Tiny Trapper with a wharnie and a clip blade.
It's an oldy but a goody.......
I carry an 80's vintage Cold Steel ClipMate (second from left) on my keychain. It'll tke some serious abuse. The Shinobu (far left) has better steel (San Mai III) but I got a deal on the ClipMate so it's the extra one I have to add to the keychain. The small sizes of these blades are around 1-1/2", but IIRC the medium size blade is only 2-5/8" so that would still be in the under 3" category. And the medium size uses the SM3 steel in both blade styles.
The Cricket can be sharpened with Spyderco's Sharpmaker or freehand with a diamond or ceramic rod. You cannot use a regular flat stone, but a small triangular rod like Lansky sells will work just fine.
As for the Kiwi, it looks like New Graham Knives has 22 different variations in stock at the moment. Spyderco makes only one batch of each variation so when a particular version is out of stock, it's gone forever.
My favorite sub 3" knife is my Benchmade 705, which is not made anymore, but can be found if searched for.
A variation of the 705 that I have bought a couple of is the Sequel 707 which has a slightly slimmer aluminum grip in place of the thicker G10 grip on the 705, and the 707 also has a slightly wider blade as well.
I saw a couple of the case ones, they do look quite nice. any idea on blade materials for them? I can't seem to find any details.
*snip*
I do like the sounds of a durable blade, but the belly is a little too much for my preferences. Shinobu looks decent, I'm still split on the tanto blades though... too bad CS doesn't make the smaller ones anymore. Thanks though!
I'll have to consider the cricket later then, I'm expanding on flat stones to maintain both the small ceramic knife, as well as the kitchen knives.
Kiwi...... so tempting, but I'll pass until a later date. After tax returns next year maybe? Hope there's another run of them by then. Looks great for general carry, but the blade looks a little too delicate for what I might put it through, and its a little long folded.
Thicker is tempting, but the folded length is a little long for my liking. The reason why I want it under 3" is because I plan on actually using that small watch/change pocket on my pants for the knife.
Ooops! I didn't catch the part about total length and was only thinking about blade length! :o
with practice u can use a small blade like the A G 2.5 titanium for alot more than u think. I carried a Buck 425 and except for large stuff did fine.
Case doesn't use super steels. Their stainless is similar to Victorinox's in behavior: Sharpens easily to a great edge, but doesn't hold it long. CV is a carbon steel that also takes a great edge and has better edge holding. I have knives using both and they're both more than good enough for my needs.
That is one of the great things for us as consumers - we have a choice in terms of steel. I for one now days only use the "super" steels - since I own a diamond sharpener, putting an edge on the super steels is not a lot of work, but the best thing (again, for me) is that the edge simply lasts a LONG time. I have knives out of ATS-34, 440C, S30V, BG-42, and now Stainless Damascus, and so far the best one is my older Small Sebenza with BG-42. It is like the Energizer Bunny - it keeps going, and going, and going ... :grin2:
Again, it is good to have the choice :)
