Search for powergenix or ni-zn and you should find posts about them. For a summary:
-powergenix ni-zn cells (same as super-z) are about 1.84v fully charged, stay above 1.6v for most of their life, considered empty at 1.3v
-they are rated 1350mah min 1500mah typical
-they are about the same total energy as 2000mah eneloop because of the higher voltage
-they are low internal resistance
-they require charging using a special ni-zn only charger
practical use:
-They run quarks, L1D, LD10s, brighter on Turbo in the 1 cell configuration compared to nimh. It's much closer to the 2AA configuration brightness than the 1AA nimh when using 1 ni-zn.
-For the Quark, and probably a few other lights, they let the circuit run at a more efficient voltage when in Turbo resulting in longer runtimes and less heat generated at the head.
-In camera flashes, they charge the capacitor way faster than nimh, likely due to the much higher voltage and low internal resistance.
