As a general rule, I dont trust factory supplied jacks. They just scare me. I keep a 10 ton hydraulic bottle jack in my pickup, along with a 12 ton hydraulic floor jack on my flatbed trailer.
Two things are a must- one is a 1/2" drive torque wrench with the appropriate socket for your lug nuts, and the other is either a jack stand or a few wood blocks. All jacks can fail, or tip over. I've seen everything from a Peterbilt to a Jeep fall off of a jack, and you dont want to be anywhere around when either one happens. Having a car fall on you isnt just some swollen toes. Speaking from experience, it's a trip to the ER, some crushed bones, and a whole lot of pain. Any time you have any vehicle up on a jack, either put a jackstand or wood blocks under it. They dont take up much space in your trunk, and they're worth it. It only takes an extra minute or two to properly secure the vehicle, which is a lot less time than you'll spend in the ambulance.
The torque wrench is a necessity, but not in the same sense. In the 70's, cars and trucks were still built heavily enough that you could just crank the lugs down with an air gun and let it go. Modern cars are different. If you go too tight, you
-will- warp the brake rotors, which can be an expensive mistake. Go too loose, and your wheel may pass you going down the road. I've had it happen, it's not a fun ride. It's even more expensive than a warped rotor. Check your owner's manual, it should list the appropriate torque spec for your lug nuts. Use it.
Besides, have you looked at the factory lug wrench on your car? It's a joke, really. Sure, you can use it, but after getting a flat tire when you're already late for work, do you really want to fight with that goofy little thing on the side of the freeway? A good 1/2" drive torque wrench and socket will not only ensure that your lug nuts are correctly tightened, but it also gives you a lot more leverage and just makes the whole job that much easier.
Just a handful of tips from a guy who's done this a time or two...:wave:
