digitaldave
- Joined
- Jun 18, 2008
- Messages
- 164
Hi all . Sorry, more questions...
As standard, the SF 6P and 6PL are single level. However, I'd like to have a multi-level light, so would it be possible to upgrade to give this function? If I've read things right, I could use the Dreelight 3SM (all their other multi-level options seem to be 18650/17670 only, not CR123/RCR123). If there's anyone that's done this, what is the output like, and what sort of run time do you get? Does it produce a flood or throw beam, and how far will it throw? Does it run off the standard tail cap? Finally, are there other easily available drop ins that will do the same job?
As a point of reference, I'm also interested in the Fenix TK11, so I'd be looking for output levels in the same sort of ball park, and with as much throw as is possible for this type of setup.
