Running two AW RCR123 3.7 volt 750mAh batteries, each reading 3.8 volts:
Stock Surefire tailcap momentary on: 7.56 volts
LIGHTSAVER MISER tailcap 1 click: 6.8 volts
LIGHTSAVER MISER tailcap idle: .4 volts
My meter just went dead, so I can't get more readings. I'll try to follow with that later.
First reaction is I like this tailcap a lot. The color, outside diameter, hash marking and rubber boot quality are all on par with Surefire and it's hard to tell they are not made by the same company at a glance. The LIGHTSAVER has a slightly higher gloss to it, hard to say if that's not due to the fact that the 6P has been rubbing around in my pocket and getting dull.
The feedback of the button is nice, it's crisp and you can definitely feel when you've hit it. It does'nt feel like a clicky tailcap, though it does click. It's somewhere between the stock momentary and a clicky if that makes sense. Clicks are: 100%, 50%, 25%, slow beacon (flash every 3 seconds) and fast beacon (flash every second). The fast beacon is not a strobe, for that you need to buy the Blitzer version, which does not have the variable output levels. Why they didn't combine these two models into one I'm not sure.
At first I thought I lost the momentary ability of the stock cap, but after playing with it for a bit I now see that any press/hold for 1 second or more acts as momentary and the light turns off afterwards. No fast morse code with this one, but CW is possible. Clicking the light on to any setting (1-5), leaving it in that mode for 2 seconds and then clicking the button again turns the light off.
Another note, it's crenulated obviously and I thought it would stand on end, but it doesn't. They only needed to make the crenulations a mm or so taller for it to stand. :shrug: The tailcap also has a lanyard hole.
Packaging/Front
Packaging/Back
Tailcaps Side x Side
Overall I'm happy with it and going to keep it. With the M60 I really needed something other than REALLY BRIGHT, and this will work just fine.
