surefire 9p, what li-ion cells and bulb are usable?
turbodog
central time
Isn't there a rechargeable solution available for the surefire 9p? Seems like it was 2 x pila 150s cells and what bulb?
Ideas?
I imagine 2 of AW's 17500 cells would fit, but please get a second opinion before ordering them. The nice thing is that li-ion cells don't suffer from as much voltage drop as CR123 primaries so if you're starting with a 3 cell light you normally don't have to change the bulb at all.
With a 2 cell it's a different story. New bulb etc...
I can confirm that two 17500s fit and work perfectly with the P90. I believe his cells also work with the P91, but I don't have one so can't confirm that.
bout halfway down the first page of the incandecent forum.
http://www.candlepowerforums.com/vb/showthread.php?t=161536
also in my sig.
in most cases, it will work, but using this setup for many cycles would eventually lead to a very high risk of rapid disassembly.... which, on a well built metal bodied light, becomes grenade like. imagine a tailcap shooting with the ooomf of a .22 caliber.
Cell configuration: 2x17500
Bulb Options:
LF D26 ES-9: 6.5W, 70 min, 110 lumen
LF D26 SR-9: 8.5W, 50 min, 140 lumen
LF D26 HO-9: 11.5W, 35 min, 175 lumen
LF D26 EO-9: 14.5W, 20 min, 200 lumen
SF P90: 8.5W, 50 min, 135 lumen
G&P G90: 8.5W, 50 min, 135 lumen
Pathfinder P90: 9.5W, 45 min, 150 lumen
WE D26 9V: 9.5W, 45 min, 155 lumen
Pila GL3 LA: 9.5W, 45 min, 155 lumen
Body Options:
Leefbody 2x18500 w/C tail and head, +SF compatible tail-cap/bezel.
Surefire [G2, 6P, C2, Z2, G2Z, M2] +1 cell extender (G&P or A19)
Surefire G3, 9P, C3,
Wolf-Eyes 9 series Raider (non-turbo)
Ultrafire/Superfire 3 cell: WF501C, WF502C,
Cabellas XPG 9V 3 cell
G&P 9P, T-9
Pila GL3
Cell configuration: 2x17670
Bulb Options:
LF D26 ES-9: 7W, 105 min, 115 lumen
LF D26 SR-9: 9W, 80 min, 145 lumen
LF D26 HO-9: 12W, 50 min, 190 lumen
LF D26 EO-9: 15W, 40 min, 235 lumen
SF P90: 9W, 80 min, 140 lumen
SF P91: 19W, 30 min, 310 lumen
G&P G90: 9W, 80 min, 140 lumen
Pathfinder P90: 10W, 70 min, 155 lumen
WE D26 9V: 10W, 70 min, 160 lumen
Pila GL3: 10W, 70 min, 160 lumen
Body Options:
Leefbody 2x18650 w/C tail and head, +SF compatible tail-cap/bezel.
Surefire [G2, 6P, C2, Z2, G2Z, M2] +TWO 1 cell extenders (G&P or A19)
Surefire [G3, 9P, C3] +ONE 1 cell extender (G&P or A19)
Wolf-Eyes 6 series sniper (non-turbo) +ONE LRB-168 extender, + copper wire mod.
Ultrafire/Superfire 4 cell: WF501D, WF502D,
Cabellas XPG 12V 4 cell
G&P 12P, T-12
2x17500's will work great with the P90. If you want to step up to the P91, you are gonna have to add a cell extender and run 2x17670's at the very least.
Yes this works. I have used this setup for quite a while now.
For people who use rechargables on a regular basis and and want to run the high output bulbs (P91, E-09, H-09) but still want the option of using primaries, I have found the Leef bodies superb.
The best cell option for the P91 is two 18650's. You can use a Leef 2x18650 body for this and add Surefire bezel and tailcap.
If you want to keep a 9P size light use the Leef 2x18500's body. Two 18500's
will power up the P91 or E-09 just fine, will run the P90 and other similiar output bulbs longer than two 17500's. The Leef body will still allow you to use 3 CR123 primaries if you wish.
On my 9P w/a WE 9v d26 bulb the AW 17500's require two magnets stacked between the cells before the tailcap momentary switch would work reliably. I use an o-ring around the magnets to prevent shorting on the slim chance that they move.
For now, I am very satisfied with the 9P+P91+A19+(2)17670's. Output stays very close to "white" for a good long while...at least long enough for me between chargings, but I haven't done any runtimes on this setup. 🙂
Same here. The batteries are slightly shorter than 3x123, plus the positive contact spring on the WE LAs is shorter than SFs. As I recall, so is the Diglight/G&P's. Lumens Factory LAs have longer springs, and work without the magnets.
I don't mind using the magnets at all with protected cells, and prefer the WE D26, so that's the same setup I have in the Z3 that gets most of my use.
Well, I have a nice new strion (with rapid charger) now. I'm not into the funky magnet thing.
Maybe this will hold me until HDS releases their new light in 2008.
