Yo wassup ma hommies !! it's HOT in here, 41C/105.8F today
Pre-Order list updated, no payment is required until your turn, when I have finish building yours. I will send a PM for payment instructions when ready. We call it pre-order list because I can only build when there is demand.
Beastmaster - no need to mod, just replace the stock bulb with the E-MT :kiss:
frisco - no problem at all, your battery will probably be able to sustain a little bit more than 1.5C, the highest current draw(I have recorded) for F1 is about 980mA.
kongfuchicken - no worries, I will PM you custom details when I am about to build yours.
jsr - Initial plan is 1000mA max. That is because the AVR Tiny used in the
E-MT FM has a 10bit ADC(1024 division) I/O and a 1.1v internal voltage reference. So I MAY be able to sense 1mA-1000mA with tolerable precision. I am NOT sure if the route I have planned will work, I need to put the thing into testing before I can confirm. Plan is fully regulated circuitry.
PLEASE DON'T MOCK AT ME IF I FAIL, I am super duper noob. Most, if not all, DIY circuit boards(and a lot flashlight) you see on DX is non-regulated.
You can
check out one of my early adventures with microprocessors here. As you can see the whole thing flop terribly because the silly placement(fundamental design) of the switch requiring a positive connection from the battery. Here's a better/more sensible Atmel microprocessor
mod of the Fenix L1P with PWM.
Sorry, as mention in post #403 I don't have a proper Lumens measuring equipment so I can't speak in Lumens.
:sigh: However, I do have a calibrated Fluke 8840 and HP 3468A bench multimeters so I can definitely speak in accurate current/mA
Silversurfer, freewheelin' - updated.
coucoujojo - Why not? at the expense of a small amount of power wasted in the current limiting resistors.
cnjl3 - nice diggin. I will let you guys know what resistor value works well. Gimme a few days. Need to dig out the switch and the resistors.
