Surefire flashlight fortitude
Dr Jekell
New Zealand
If this has come up before please excuse my ignorance but:
What amount of abuse will the personal line of Surefire flashlights (6P, 9P etc) take before the bulbs go?
I am a Volunteer Events medic and a QA manager who starts work in far too early and has to fix things that are an places that are not designed for human bodys to fit into.
I am trying to decide between getting a 6P and a 9P or an M2 and an M3.
With my medic job I could be doing anything from working a fair, sports, working in/on/under vehicles/boats, running around some very steep hills with them in a cargo pocket, droping them, haing them throwen into my medic bag.
On my other job I could be using it around hot steam/equipment, water, in a freezer, in/on/under heavy equipment
They would be carried in the two outside pockets of a Maxpedition Thermite Versipack outside of work.
Any ideas :candle:
JanCPF
Denmark
Surefires will take most abuse including what you mentioned, but eventually the bulb WILL fail on you, so I would recomend the L5 from their LED line instead. It's very versatile and bright, and built like a tank. The 5 watt Luxeon LED won't suddenly go dead on you, and you will have a constant reliable output of about 100 lumens for one hour. It is however a little more expensive than the 6P and 9P, but well worth it IMO. It has a wider beam, so it won't throw as well as a 6P or 9P, but if that's what you need, Surefire has got the KL3 head that fit the L5, 6P, 9P, M2, C2, C3 bodies.
Jan
Grox
Melbourne, Australia
With your needs, I would probably go for an L2 or an L4.
Surefire makes, IMHO, the best incan lights available. The surefire hallmark of ruggedness is also visible in the L series. The L2 will give you 2 levels but at the cost of physical length. This may be an advantage as it will more readily stay upright in a cargo pocket. The L4 will only give you one level of light but comes in a nice compact package.
Runtime may be a concern for you and you may have to switch batteries frequently. There are rechargeable batteries available for the L2 and the L4 which will slash the cost of running the light. Have a search on the forums for a member called AW who sells these cells.
Any of the surefire LED lights should be able to withstand at least as much abuse as your body.
chesterqw
singapore,jurong
i will advice you to get the m2 and the m3.
becuase led lights especially the luxeon V ones isn't going to have a long live in hot steam conditions. so unless you work you a real cold place everyday, the leds aren't really for you.
the m2 and m3 have a shock absorbing bezel, which will take away most of the shock to prevent the e.g. recoil from guns causing the filament to burn out.
or you can get a led and an incan e.g. the M3 and L6 (note that because they are of the same size :p)
use the l6 in freezing condition will be real nice as leds like working in colder condition
the m3 in hot conditions. and both for water
and for heavy equipment, both.
Paladin
Working around electrical powered gear a plastic bodied light might be safer. An L5 dropped between a buss bar and ground would make a spectacular "exhibition". I wonder if you should just consider the Streamlight multi-LED ProPolymer 4AA for your repair jobs, and a SL 4AA Luxeon for emergency responses.
I LOVE Surefires, but it sounds like your life style might be highly prone to the loss or damage of the light if forgotten or dropped...Streamlights are working tools you won't cry over, but an L5 lost would be a big deal to me. Also you could pick up a TL-3 to have a cheap beater with some throw. Both ProPolymer LED versions and an incandescent TL-3 will cost less than a single L5. With money left over for getting a rechargeable AA battery system!
Try the Streamlights, and if they are found lacking for your duties you can transfer them to the "emergency kit" every prepared individual should have for power outages and natural disasters anyway.
Paladin
webley445
St. Pete, Fl.
A consideration for your medic work, these lights will possibly be too bright for checking pupils.
I too make the suggestion of using rechargeable power if you use your lights so often. there are many options (i.e. streamlight Strion).
What is the budget? And are you adverse to having more than one light?
And look into good lanyard and wrist strap for helping keep the light "handy" and in reach.
There are hand made lanyards and straps here in the forum you can read about and inquire about if you're interesred.
turbodog
central time
I would look at a streamlight strion.
I gave on to my 2 year old daughter to play with when I wanted to see just how much banging it would take to blow the bulb.
We live in a house with a bare concrete floor (stained and scored). She banged it all over the living room for about 30 minutes. She used it as a hammer.
It was turned on the whole time and the bulb never blew. The bulb didn't even die a premature death later on.
I got several good dents in the bezel but no blown bulb.
Brighteyez
San Jose, CA
Run time by specification is 70 minutes, though in the real world, factors like usage, ambient temperature, age of battery, and battery condition, are all subject to lowering the run time.
LawLight said:
What kind of life does the Strion have on a charge, before needing to be re-charged?
-Kev
Illum
Central Florida, USA
no matter what you choose, incan or LED, bring a backup...even as small as a photon or a stylus...when the bulb of your light does fail...you wont bang your head into all the obstructions while "fix[ing] things that are an places that are not designed for human bodys to fit into."
Good Luck, regards
greenLED
La Tiquicia
:laughing: Little kids are the best flashlight testers!
My son was playing with my L1p the other night, and my wife says: "Have you ever thought that if you gave that light to any kid his age, they wouldn't know what to make of it, yet your son knows what it is and how to operate it?" Ah... what a proud Daddy-Flashaholic moment that was!
Ty_Bower
Newark, DE
Someone ought to start a thread about children and flashlights.
My not quite 2 year old son is definitely a hotwire addict. He always goes for my Mag mods. The brighter the better. I've got the Gordon 3C hybrid (clone of the Streamlight TwinTask 3C?), and he invariably turns it on to the xenon lamp, every time. I switch it to the LEDs, and he hollers and stamps his feet. Then he clicks the button until it's on the xenon lamp again.
My almost 5 year old daughter seems to have a thing for my red L1. She calls it the "blood" light, and always wants to tell "ghost stories" when she sees it. She has mastered the HDS, and can double and triple click to change levels. I was out working on the car brakes, and asked her to bring me a light. She grabbed the U2, brought it to me, and told me she had already "turned it to brightest" for me.
And yes, more than one of my lights have a ding or a scratch or worse from the kids.
Trying to get back on topic, are we sure the Surefire M series are truly shock isolated in all axes? I thought the shock isolation was primarily intended to protect against firearm recoil, which ought to be mostly in one direction. And as far as Surefire L series LED lights being unsuitable for anything other than "freezing" enviroments, I'm not sure I agree with that one either... :thinking:
Dr Jekell
New Zealand
Hey guys just an update:
I prefer Incans to LED's due to eye problems (the bluish tint can give me eyestrain and a headache) :sigh:
For my QA job I work in a restaurant so the areas I would be working in are near grills, steamers, working on computers, wiring, plumbing, In/On/Under/Behind heavy equipment, in false ceilings (very tight fit), inside cupboards, in a walk-in chiller and freezer – basically I'm a jack of all trades master of none ;)
Also I usualy don't work around electrical cables, connections etc as in NZ all electrical work done in restaurants has to be done by a registered sparky
On my medic belt I have a LED Lenser V2 for general lighting when getting another light would constitute overkill (Not that it is a bad thing though), which I will replace with a Fenix L1P
I will not get most plastic lights unless I have had rave review from a friend – I suppose that could have something to do with a school camp and some caves :aaa:
I do own a G2 and I am going to put that in my medic bag (where I stick all the stuff I take from event to event) when I get the lights that I am deliberating about
When I check a Pt's pupils I use a pupil torch - unless they get on my bad side :devil: (considering a Streamlight Stylus LED Penlight for the job)
I am still 50/50 with regards to the Strion, as I haven't had much chance to research it yet – working too much :sleepy:
How do they compare to the SF 9AN Commander in terms of performance, lumen-rating aside of course?
I have to save up my money :broke: for the lights but I am patient and can wait (barely)
I EDC @ the moment a A2, G2 and an energizer key ring light which are keep in my Maxpedition bag
I have to blame you guys for causing a rapid advance of my Flashaholism, each time I log into CPF I have to add another light to my list of lights to get/look at/consider that just keeps getting longer and longer
As to "fix[ing] things that are an places that are not designed for human bodies to fit into." That is the fun part of my job! The crew take sadistic pleasure in breaking equipment in the most inaccessible places then leaving it for it to go from bad to worse then calling me to fix it :whoopin:
Also about 50% of the events I cover as a medic are either wet, muddy, dusty, dirty, or all of the above so the lights need to be able to handle that.
Thanks for all the input – You guys rock! :rock:
Illum
DUQ said:
With the details that you gave us, I also vote for a Streamlight Propoly. I also work in the same environments as use described. I carry a Fenix L2P but my main work light is a Mag 3D LuxIII. If your not set on an SF, I would strongly suggest you think about the Streamlight line.
http://www.streamlight.com/propoly_family.htm
I second that! :rock::rock::rock:im thinking of buying a couple more 4AAs...one for each bathroom and one to hang on each exit door...same way one would hang fire-extinguishers in every room :grin2:
chesterqw
singapore,jurong
the SL luxeon propolymer rocks.
either the 4aa or 3c will rock your world!
PLZ PLZ PLZ don't use it to check the pupil of the eye.
they will see some nice spots after that which will last for a quite long time.
Dr Jekell
New Zealand
As I mentioned in my last post I will not use them on a pt's pupils! unless they get on my bad side - that is not a very easy thing to do but there have been a few of those :devil:
