What exactly is meant by "four-die LED"? Is that four LEDs on a single die?
Is that Black HA?? If so, will SF release a Natural HA version to match current M3, M4 and M6's?
Yes. The SSC P7 is, as MattK described it, a Lux V on crack. Four high flux SSC dies crammed together into one emitter. Somewhere between an R2 bin cree and an Osram Ostar in crazy-ness.
With it being a 4 die like the Lux V, I hope there's no doughnut hole in it. Maybe they've improved the optics to go along with it?
I would worry more about a relatively early burn out rate due to 2s2p configuration (if that is how they do it).
Note that the UA2 (with the spot to flood variable beam using a pair of optics) is being rated as up to 200 lumens.Surefire will work the bugs out. It will be one of the last new lights to appear this year. Paul Kim had a rough prototype at the Surefire party he threw for CPF, so still in infant stage. He did demonstrate it. the new U2 variant will be out sooner. Variable output with ring up to 200 lumens, including strobe.
Bill
Hopefully SureFire! :devil:Does anyone know what emitter the UA2 will be using?
Chris
Yes - the KL9 will fit the M3 body (which is the same as the L6 body). Indeed PK showed a proto-type of the KL9 on an M3 body at the CPF/Flashaholic PartyHi,
I have M3 light. Will the KL9 possibly fit those bodies? I am not familiar with Surefires weapon systems and don't know the relationships with the hardware.
Where is your E1e? In your hand? In your pocket?Hey Al, where the hell is my beloved E1E?? I didn't see it in the new catalog...
