Gerhard
Hi,
I have a Surefire L1, and today I noticed that the tailcap switch is stuck. The part in the tailcap that moves back and forth when you press the rubber cover on the back of the light no longer moves freely. You have to push it fairly hard to get it to move back to the "off" position - stronger than the spring mounted in the tailcap that presses against the battery is able push. The light now only works in the "twistie mode".
Has anybody else had such a problem before? What do you recommend I should do?
Thank you,
Gerhard
Thank you,
Gerhard
