flashlightsarecool
- Joined
- Mar 14, 2014
- Messages
- 70
Used to own a z2 with m61 drop in. The led would flicker in momentary mode with the z41 tailcap and another z41 with mcclicky installed . This problem went away once I replaced the keeppower 2500mah 16650 with primaries.
Just got a 6P with another m61. Same thing. Z41 and mcclicky flicker in momentary with 16650. Works fine with primaries. What gives?
Also the z41 tailcap spring is quite sharp where they cut the spring. It's put a pinhole on the negative side of the 16650. I'd say about a mm deep. Safe to use? Once again no pinholes on the bottom of cr123's.
I know the light is designed for cr123's but so many people say they run a 16650 in these lights. Any insight is appreciated.
For the record all my Malkoff drop ins in Malkoff lights work perfectly with primaries and rechargeables.
