this_is_nascar
I only know of (1) person who has claimed using an RCR2 in the Titan. Is anyone else using an RCR2 with regularity in the Titan?
mine been working perfect with CR2 li-ion!
I'd be surprised with all the R&D Titan received, if it doesn't have li-ion support. for self protection purposes if nothing else....
have only ran through a few charge cycles now... still have not ran cell down below 3.5v.
retired my old CR2 li-ion cell as it would only charge up to 4.02v.
new cell charges up to 4.14v.
don't know about anyone else, but I've had a tendency to twist fully on to max position. which drains cell quickly.
close to two years later update...
Titan has been my primary EDC via neck lanyard. have retired my Ti PD due to non use with Titan around.
Titan has given me a few hicups with light acting erratic as many others have reported. discovered the fix... take battery out, then twist bezel/switch fully 30+ times. this cleans up the switch inside, fixing erratic output issues.
have completely changed use pattern... seldom is full power used. have not used li-ion CR2 for a year+ ... primary CR2 only... a cell typically lasts 4-6 months of constant use. I'll dial in exactly amount of light needed. which is seldom high, titan will run days on low.
I have tried twice to use rcrcr2 cells once with regular AW protected cells and with then with the 3.0v cells from dealextream /kd.I used the 3.0v cells for a short time and and they were ok but when I started having erratic operation I switched back to primary cells. using the 4,2v cells caused an imediate flickering and the low was a little higher than with primary cells I don't know if the light would have settled down as soon as the processor figured out the voltage or not,however it works good for me with primarys so I am sticking with them for now. Mine is the original Ti version
Anyone upgrade the LED in the Ti Titan?
The first run, Titanium one?
