Justin Case
- Joined
- Mar 19, 2008
- Messages
- 3,797
Post deleted.
I recently re-mod'ed this U2A by installing a neutral tint XM-L T5 bin LED. As expected, the hot spot lux dropped, although I had hoped for less of a decrease. The lux went from 11,400 with the XP-G R4 to 8200 with the XM-L (basically back to the original value with the Seoul P4). The current draw on 2xAW16340s is about 0.4A, with a total power draw from the batteries on the order of about 3.15W. With the XP-G, the U2A used to draw about 3.3W, so power consumption has dropped by about 5%. The XM-L Vf is about 2.9V (was about 3.1V), giving a driver efficiency in the mid-80% range.
I'll get a beam shot similar to the one in post #8 later. The XM-L beam pattern is very similar to the stock P4 beam. The XM-L hot spot is larger, but both beams have that same smooth blending of the hot spot into the corona. The XM-L also puts out noticeably more light in ceiling bounce vs. the P4.
If your U2A already has the threadlocker defeated from a previous mod, then this XM-L mod is fairly easy to do if you have the XM-L on an 8mm diam board like the datiLED board. You need to shim up the board about 1.2mm to get the LED die to the same focus height as the P4. The 8mm diam board fits perfectly between the centering ribs of the U2A heat sink. Thermal glue the shimmed board into place, solder the wires, and screw on the top half of the head.
