I need to drive a single Osram Golden dragon IR emitter, with controllable intensity, from "off" to full power.
I need it to run from 5V - 10V input.
I need the intensity control to be relatively simple, like a variable resistance to ground.
Now the kicker: I need it to be efficient.
You wouldn't think that was so hard, would you? I've searched for hours, and not found anything much over 70% efficient. All the drivers seem to be optimized for white leds (higher Vf), lower currents, and strings of many leds.
:confused:
The National Semi web seminar on LED drivers has all the same issues, nothing that works for me.
Could anyone point me at a possible solution?
:confused:
