TA30 Question.
AOBRICK
PA
I have been kicking around replacing the surefire 9P mounted on my AR-15 with a TA30.
Where do I find the pressure switch for the TA30 if its available at all?
IIRC the entire TK series pressure switch (with exception of TK40) works with TA30.
You can check that the TA30 Instruction Manual says: 'When using the Fenix remote pressure switch, depress the pressure pad to activate the light, loose to turn off.'
This means IMO that the usual pressure pad can be used also with this light. It should be easy to get a confirmation from Fenix. :)
The TA30 can use the tailcap from TK11, that probably means that the pressure switch will work to.
