[ QUOTE ]
ABTOMAT said:
...snip...
KC2IXE, what do you have against the AA Craftsman lathes? The only real problem with them is the undersized spindle bending. Most folks have made their own solid ones now. Just treat them as a 4" (never should have been made in 6" sizes) and you're fine. Of course, they're pretty pricy now the way very small vintage lathe prices have gone.
[/ QUOTE ]
You about summed it up - too many folks I know found bent spindles, found problems buying new chucks for the small spindle, and they cost as much as the Atlas version, which is a lot more lathe for the buck.
As you say, if you treat them as a VERY light duty 6, or as a 4" lathe, they are OK, once you check things out. Solid spindles limit you
Me? I have a 12" "commercial" Atlas with almost every tool that was offered (yes, even the lever collet closer and turret tailstock) - Just about the only thing missing is the BED turret. I "stole" the basic lathe, in PERFECT condition for $450, and have since tooled it up
The BIGGEST limitation of that lathe, and the thing that drives me nots about most small lathes is the size of the hole through the spindle. It's 3/4" on the 12", and once you put the lever closer in, it's 1/2". I run a production job that would be PERFECT for the the lever closer, except it takes 5/8" stock /ubbthreads/images/graemlins/frown.gif
One day, probably in the next few years, I'll replace the Atlas - I'm thinking 10ee or HLVH- the big problem there is lack of length between centers. I don't have the room for the LONG 10EE. Another choice I'm thinking about is a Sheldon. The BIGGEST problem with all of these is ROOM - My shop is in the basement, and rigging the stuff down (and UP) isn't fun /ubbthreads/images/graemlins/icon3.gif
