Tech question re: Fenix LD-20
detwolfsdad
Seattle Wa, USA
Hey Ya'll
I read a post this morning that got me to thinking (Danger Will Robinson). Could I use 1AA battery and a spacer/dummy in a Fenix LD20 in an emergency to conserve batteries. If so what would I use/how would I build the spacer/dummy?
These came out of a realistic handheld cb I bought back in the mid 80s. I did a search for the dummy cells and couldn't come up with anything. Somebody still has to make these things?
Hey Ya'll
What do you mean by "conserve"? Using one cell will use less batteries at a time, but using two will be more efficient, running longer than using two seperate loads of a single battery.
+1, this is true.
The Fenix LD20 will run on a single AA - but its maximum/Turbo output would be reduced to that of a LD10.
I believe the Fenix LD10, LD20 and PD20 share basically the same head - so one can play "Lego" with the bodies.
It may be simpler just to get a LD10 body to use the LD20 head to get a "real" single AA light -
while you're at it might consider getting the PD20 body to have a single CR123 configuration as well.
Actually the LD10, LD20 and PD20 heads will also fit on the older L1D, L2D and P2D bodies.
+1, although I think for clarity purposes technically you'd look for the L1D body (which is compatible); I don't believe they sell a LD10 body separately.
They have come on the market in the UK in the last couple of weeks, so that would probably be a relatively cheap and straightforward solution. About £17 here.
Worst case scenario, a person might only have one battery left :eek:
