temporary 18650 charger
yes, you can do that if the charger is charging 3.7V RCR123A cells (to test, use a multimeter and measure the voltage of a fully charged cell. if the voltage is ~4.2V, then it should work.)
but the charging will be slower.
hi how2 yes the channels turn green once battrey has charged so if i put one in the left channel , the left go green once charged same as the right one so yours must have a fault m8 :o
