Tenergy Batteries
I have 32 of their "R2U" 2300 mAh double A NiMh cells in more or less regular rotation, in a variety of devices. No problems so far.
This seems to be their US sales operation: http://www.all-battery.com/index.aspx I've had very good service, prompt and as described.
I got a couple of Tenergy li-ion's from 4 7's for my Zebra H60 and seems to be working just fine. Given the amount of quality service attributed to them they would choose a readily available quality li-ion brand.
I also had ordered a additional 12 or so pack of 123's for my sure fire 9P Malkoff combo from battery junction about a 1 1/2 years ago and they worked great. They were also the Tenergy brand.
Using the SEARCH engine will allow you to make a much more informed final purchase and may or may not direct you toward a different brand.
CPF Market Place would be a good area to browse for very current opinions.
Now is good time to buy a good charger and tester too; if you're getting into the high end rechargeable arena.
I have these as well; according to the BC-900 they are overrated. The best I have measured is 2.00 Ah. But for about $1 a cell (keep checking for sales and specials) they aren't too bad.
I've used Tenergy NiMH batteries for 3-4 years now. I also have a couple of their smart chargers. I would rate them just below MAHA as far as performance. I consider MAHA the best for NiMH.
I've never had one go bad yet and still buy from them. I just wait till what I want if free shipping and then order it.
I must have about 50 of the AA, 20 of the AAA and several D cells too.
They have done me right so far.
I go to all-battery.com they are cheaper there, usually.......
I've found that it really depends on the battery size and even batch. In the past I've owned some terrible RCR123's that were so poorly constructed that I gave them away. Since then I've be using some "3.0V" RCR123's that all test well above 3V and as high as 3.6V. I did receive several Tenergy 18650's and the construction is excellent. The only issue that I have with all Tenergy's is that their all rated at higher than actual capacity. My AW and LG cells almost always outperform them.
Now this is a good thread since i only have there rcr's........for the price it seems that you cant beat it.
