Tenergy RCR123A (3.0v) battery
Ragdoll
HK
Has anybody used a WF 139 charger to charge Tenergy's RCR123A (3.0V) battery? Or it is a must to used Tenergy's own 3.0V charger?
I just bought 2 RCR123A batteries but dare not try them with my WF139 charger.
Any information would be much appreciated. Thanks.
The WF-139 is not to be used with 3.0V RCR123A cells. I recommend using the tenergy or another 3.0V RCR123A charger.
There seems to be a difference between there 750mah and 900 mah chargers also - not sure why but I've been charging the 750's in the WF-138 which has a 3.0 volt switched setting. Charging them with the WF-139 would almost surely ruin the batteries unless you had a voltmeter on them and watched it constantly while charging - probably a bad idea. Just get a correct Tenergy charger - I think BatteryJunction has them on sale for about $10.
