I am kind of puzzled as I just purchased 8 tenergy lithium rechargeable cr123a's and they won't work fully charged in a surefire C3 with the optional p91 high output lamp. They work fine in P6's with lamps or led's... and they work fine with the p90 surefire bulb. The batteries are new and fully charged one cycle.
Is the high current bulb too much drain for the batteries ??? they won't even give me light output for a minute. I don't believe that the flashlight has any regulation or circuit ... just contacts and power and resistive load. The batteries might have some sort of current limiting circuit inside, but there can't be much room inside the cells... I even tried two primary batteries and one rechargeable... still no go. The flashlight works fine with different batteries. The batteries work fine in several other surefire lights with bulbs or led modules.
Any insight would be appreciated.
