HKJ
[size=+3]Ampsplus 18650 3500mAH (Black) 2020[/size]
Official specifications:
This is high capacity protected 18650 battery with a fairly high current limit for a protected battery.
The two cells match nicely, but the protection do not protect a high continuous current, there I stop due to temperature.
I forgot to mount the thermo sensor on one of the batteries.
Even without thermo sensor it trips after some time at 15A.
[size=+3]Conclusion[/size]
It is a good battery, but with the protection the maximum continuous current is about 10A continuous or 15A peak. The protection do also provide over discharge and charge protection (They always do).
[size=+3]Notes and links[/size]
The batteries was supplied by Ampsplus for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
- Battery Size: 18.40mm x 68.85mm
- Nominal Voltage: 3.60V
- Nominal Capacity: 3500mAh
- Min. Rated Capacity: 3400mAh
- Charging Method: CC/CV 4.20V +/-0.05V
- Discharge Voltage: 2.70V (Average Cut Off)
- Standard Charging Current CC: 1475mA
- Standard Charging time: 270min.
- Continuous Discharge Current: 10A
- Protection Circuit Trip Cut Off: 2.75V
- Battery rate: 3C
- Weight: 49 gr.
- Colour: Black, Silver, Purple
- Protection Circuit Board / PCB: Yes/ Protected (Maxell)
- Version: Button Top
- Type: Rechargeable, High Drain, NCR
