Test/Review of Efest IMR18650 3000mAh (Purple) 2016
HKJ
Copenhagen, Denmark
[size=+3]Efest IMR18650 3000mAh (Purple) 2016[/size]
Official specifications:
  • Rated capacity: 3000mAh
  • Nominal voltage: 3.7V
  • Max charging current: 4A
  • Standard charge: 2A
  • Max continuous discharge current: 35A
  • Pulse discharge current: 60A
  • Charging temperature range: 0°C ~ 45°C
  • Discharging temperature range: -20°C ~ 75°C
  • Inner resistance: 20mOhm
  • Cell size: 18.5mm x 65.20mm
High capacity and high current cell.
The cell is very good up to 20A, but at 30A I terminate the test due to temperature. The tracking between the cells shows that they are very well matched.
Temperature raise at 15A load, to get the real cell temperature add (about) 25°C to the temperature.
I had to stop here, my rig melts at this temperature (I hope to improve this).
This is also the maximum discharge temperature for the battery.
[size=+3]Conclusion[/size]
The battery has very good performance, 20A is no problem, at 30A it is probably best not to use continious discharge.
[size=+3]Notes and links[/size]
Improvements to test stations
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
Thanks for the test/review! I am just about to purchase some 18650`s, this helps alot.
Battery reviews like yours are a big plus in my book,and others i am sure. I wish i would joined this forum a long time ago then i would not have wasted so much money on ,"cheap" 18650's. If i remember they were Trustfire's maybe. They didnt hold a charge long,then soon after they would not charge at all.
Thanks for your excellent review. HKJ! :thumbsup:
Discharging temperature range (-20°C ~ 75°C) is the internal temperature of the cell?
Efest is OK for a single-battery flashlight. For a multi cell flashlight I would avoid them, because of the potential for mismatches.
I don't know what we would do without your tests!
Can you estimate how much improved the graphs look due solely to your upgraded equipment?
This is why I love cpf, thanks all for the detailed info.
Is this the same type battery that exploded in the guy's pocket?
Since the 3500 mAh version varies greatly in performance I would be hesitant to even try this.
