Test/review of Keeppower 21700 5000mAh P5150TC (White-Blue) 2020
HKJ
Copenhagen, Denmark
[size=+3]Keeppower 21700 5000mAh P5150TC (White-Blue) 2020[/size]
Official specifications:
  • Voltage: 3.60V
  • Typical capacity: 5000mAh
  • Minimum Capacity: 4900mAh
  • Discharge cut-off voltage: 2.50V
  • Charge voltage: 4.20V +/- 0.05V
  • Standard charge current: 1300mA
  • Maximum constant discharge current: 8A
  • USB type-C charge socket.
This is a 21700 cell with build-in USB-C charger, the cell is a protected high capacity cell.
The two cells match just about perfect and can easily deliver the rated 8A.
The USB charging uses a switching regulator to keep the heat down, I measured about 10°C temperature increase at the front of the cell during charge.
The USB-C input do not follow any protocols, except signalling it needs power.
[size=+3]Conclusion[/size]
It is a good battery and the USB charging means it can share charger with a mobile phone, this is very practical when traveling or when having only a few LiIon batteries. Only caveat is that the battery is considerable longer than a standard 21700 cell.
[size=+3]Notes and links[/size]
The batteries was supplied by Keeppower for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
What happen if I plug the usb cable while the battery is still in the appliance?
