Test/review of LG 18650 HA1 1300mAh (Green)
HKJ
Copenhagen, Denmark
[size=+3]LG 18650 HA1 1300mAh (Green)[/size]
Official specifications:
  • Nominal capacity: 1300mAh
  • Ninimum capacity: 1200mAh
  • Standard charge: 650mA, 4.2V, 50mA
  • Fast charge: 4000mA, 4.2V, 100mA
  • Max. charge voltage: 4.2V
  • Max. charge current: 4000mA
  • Standard discharge: 260mA
  • Fast discharge: 10000mA
  • Max. discharge current: 20000mA
  • End voltage (Cut off): 2.5V
  • Operating temperature: charge: 0°C ~ 50°C, discharge: -20°C ~ 75°C
  • Storage temperature: 1 month: -20°C ~ 60°C, 3 months: -20°C ~ 45°C, 1 year: -20°C ~ 20°C
  • Initial AC impedance: <30mOhm (Without PTC)
  • Cycle life: 400 cycle to 60% with fast charge/discharge.
This battery is a high current battery of a fairly old type.
The battery has fairly constant capacity up to 15A.
Due to the fairly low capacity, the battery keeps a moderate temperature.
I used the capacity while doing these measurements.
[size=+3]Conclusion[/size]
The battery is orginally from 2006 or 2007 and was probably designed for use in electric tools.
[size=+3]Notes and links[/size]
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
HKJ
Copenhagen, Denmark
Over the next couple of months I expect to publish more reviews of older cell, there will also be some never cells that I am missing.
These test is done when I do not have newer batteries to test.
vicv
Southern Ontario
I have ten of these. Been using them for 6+ years with hundreds of cycles. Capacity and ir is still basically the same as when I got them from a ryobi drill battery
