The future is here: Lithium titanate battery
NickBose
I'm not sure if someone has posted but here it is
PDF file
What else can we ask for?
160mAh/gram
Stable to 700o Celcius
Charge to 90% in 10 minutes
15 times the cycle life to current LiIon
It looks very similar to A123 nano li-ion technology. Look at page 10 of the pdf document you linked. It has only half the energy density of regular li-ion (but much better power density)
What is the difference between power density and energy density?
Power = rate of energy
in SI units energy is measured in joules, power is measured in watts = joules per second.
In flashlight terms, more energy density = longer runtimes. More power density means that it can put out this energy at a faster rate e.g. it's capable of running higher powered bulbs etc.
Nick, high power density means you can use a low capacity battery at high discharge- i.e, 16340 sized to drive several quad die LED's safely, whereas a "standard" li-ion in that size can't even run one at full power without seriously decreasing cycle life. (max discharge ~1.5C for li-ion)
There are many new developments in Lithium Ion batteries in all aspects of their components. It is too early to say which will prevail in different areas. Having adequate capitalization, reliable production, effective cost, purchase contracts, public demand, distribution channels, marketed product lines, etc. etc. are likely more important than which brand has slightly better energy/power/weight densities.
Having electric vehicle contracts with major automakers or military suppliers will move one brand forward. The consumer cylindrical (i.e. AA, 18650, etc.) battery demand is a whole other set of markets that is dominated by Energizer, Duracel, Rayovac, Panasonic, Sony, Kodak, Sanyo, etc. They will decide which Li-Ion technology they want.
