Greetings all. I've been diggin' around but not finding exactly what I'm looking for...
I'm looking for a white LED light suitable to keep in my flight bag, use for preflights, and use as an aux light in the cockpit. I fly single-rubber-band airplanes, so throw isn't a big requirement, but something that has a 100+ lumen output has more utility. Also, for me, FAR part 91.501 and 135 do not apply, so I don't need a flashlight powered by 2 D batteries.
Basic requirements:
Other thoughts:
I was looking at the Jetbeam RRT-0, until I found out that you have to go from low->high->low to get the lower low (which is still 1 lumen and probably too bright). Is it just me, or does this sound dumb if you've got a rotating brightness ring to begin with? Some have also reported bright flashes when you turn it on. Other than that, the ring is a good idea.
I've also considered some of the 4seven's quark lights with moonlight mode (the mini doesn't have it), which might be perfect output-wise, but the UI seems conducive to accidentally starting in a higher mode, or bouncing the button and ending up in a higher mode. My other option would be the tactical versions which memorize modes, but then switching to anything other than the 2 stored modes is difficult... This may be my best bet though. Any personal experiences?
Accidentally firing 180 lumens against a chart in a cockpit is a bad thing.
I also have an original generation Surefire L1 (~3-5 lumens on low, too bright), an Surefire U2 (low too bright), a cute little quark mini as EDC (low too bright), and some random cheap knock offs (too bright or too unreliable).
Thoughts?
Basic requirements:
- Very low (<1 lumen) mode
- No stupid UI that requires you activates higher modes first before low
- Easy change from lower modes to higher modes and back
- Way to assure a start in lowest mode.
- Some mode in the 100+ lumen range with modes in between.
- Clicky design a plus; momentary a plus.
Other thoughts:
- Looking for white, not red.
- Already have a photon microlight III that I keep clipped to my headset cord, but half the time I go to use it it seems the batteries are dead.
- I carry 123's and AAs in my flightbag already, so battery type not critical (123's kinda preferred).
- At $100+ an hour for gas and plane, flashlights in the $100+ range are acceptable.
- Open to thoughts on R2 vs R5 emitters
Thoughts?
