The "new" beast
350xfire
Texas
So after a few months in my new home I found another one... Had to beg a little to get wife's approval but she finally caved in.
The good-
1. AMERICA IRON!!!
2. Bison chuck- only 6" but a bison it is.
3. Headstock bearing play- about 4 thou in and out(can be adjusted... About 2 thou up and down. Around a non-calibrated Maglite barrel about 2 thou. Not bad!
4. 3ph motor.
5. Taper attachment
6. 30" bed makesd the unit smaller and cheaper DRO scales will be needed. My other Leblond was about 60" bed making it wide and the DRO scale for the X was another $100.
7. Some bed wear but not a big deal... When the carriage lock down screw is partially engaged below the chuck, the carriage gets tighter as it is moved away from the chuck towards the end of the bed. Not too bad though. My other Leblond was worse.
8. I have a 4 jaw 10" chuck , assorted backplates and collet closer that I kept from the other lathe!
9. A bit lighter in weight.
10. Cooler legs with storage.
The bad:
1. Spindle bore only 1.1"
2. Now I need to buy VFD.
3. No tool post so I need one. I would love to have another KDK!
4. Machine a bit dirty and greasy, will take a bit to polish up. I love a challenge though!
5. 6" Bison... At least a Maglite barrel fits into the chuck nice and deep. I will eventually get an 8".
6. Kind of a small 3/4 hp motor... Not sure how this will work but my other Leblond had a 1hp and worked well. Although, I could feel it straining on big passes.
That's it for now!
Plans for a full resto? If yes, please post your progress! Congrats!
I plan to buy an old lathe one day for a resto project. I think it will be a lot of fun! They don't pop up too often around here. Man would I love to have a Monarch or an old Mori Seki, can't afford it though.
Yeap, Leblond Regal 13". I'll call tomorrow and see what age. One nice thing about the old American stuff is that the manufacturer's are great about having the information on the machines. My old 13" was a 1944 model and they knew almost everything about it!
Alright, here's some more eye candy! Clean up in progress. Leblond said it's a 1943 model that was sold to the government.
Daughter says "approved"!
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Sweet! That'll be fun to clean up, I can't wait for the after pics. I found that scotch brite and WD40 works really well for removing the surface rust quickly although it just put a scuff pattern in the metal.
Oven cleaner works well also and removes paint. So if you don't want to remove paint don't use it.
Spray, let is soak a few hours and wipe off. Repeat as needed. It's only about $1 (generic brand) per can so very cheap.
It hurts my soul to look at a gorgeous older machine because it makes me realize how ugly the newer Chinese machines are. Everything on the Regal is sculpted, rounded, meant to touch & use for years. Reminds me of my South Bend. Pretty enough to display in the family room even if it never makes a chip.
I agree Barry. These things are sweet. I almost bought an 11x Chinese machine that the owner bought and never used (at least that what he said). After using my other Leblond, I knew I wanted another American Beauty. I spent a few hours last night power washing parts and picked up a can of ANSI Gray Sherwin Williams to do a cosmetic resto on it. Spindle bore is not as big as lathes of today but I can work around it.
I do need a few parts for this one as some were missing. Luckily I kept the 4-jaw Cushman and collet closer from the other one I had. Now I really only need the steady rest. It has the follow rest.
EBay often has "unknown" steadies that can be adapted. Sometimes they have to be cut down & welded, other times a V-groove will need to be machined. Cost is usually low.
gloves and eye protection the boy of I guy I worked with way back burnt the ---- out of his hands stripping paint with easy o
Indeed. That is a pretty strong sodium hydroxide (caustic) mix.
Started to paint her tonight. Also bought a NEMA 4 TECO VFD drive for her. I like the fact that it has a FWD/Rev switch, on/off switch and a pot for adjusting speed.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Not trying to cause undue concern but that old motor may not like your freq drive :(
The older motors were manufactured before the birth of solid state electronics. Their insulation is fine for running from 120 or 240 volt power but not for the very high bus voltage present in the VFD waveform. You may want to retire that motor to a less stressful job & pick up any newer Baldor (or equal). All have ISR (inverter spike resistant) insulation & are designed for freq drive control.
Precision, my old Leblond with similar motor did not have any issues. What would happen if issues were to be present?
Thanks
Thanks
Nothing to say this one will not work, Barry said it may not like the V Spikes inverters tend to create. Voltage spikes may not kill a motor instantly or at all but if the insulation is not up to the task it can be penetrated by a small arc. if it continues the insulation will continue to break down until there is a hard contact of the wiring at which point the motor will create a high current condition and either over heat/burn or pop a circuit breaker or fuse. Worst case you could have a fire from burning debris falling out of the motor and igniting other fuel sources around it. Or it may just stop running from a popped circuit. Too many variables to say exactly what will happen.
