markr6
- Joined
- Jul 16, 2012
- Messages
- 9,258
WOW! I almost want that cooler 700! With the 3 I already had, they were so consistent that I can't believe yours is that much cooler. Thanks for the photo!
I guess there's some small difference in the spill but nothing blue. I remember those days of purple but it's been a while. The "5000K" zebralight mentions is a joke; nowhere near that. Compared to my other 5000K lights, it's not even close, 4000K at best.
But I can say the same for my Emisar D4S Nichia 219C at 5000K. NOWHERE near that. Again, 4000K or so. But compared to the SC700d, they are very similar in tint and CRI.
USPS tracking finally updated. On Monday, I'll get to try out the SC64c LE.I just got a shipping notice for the SC64w HI and SC64c LE that I backordered on the 16th. That's much quicker than I anticipated. I will report back with tint comparison thoughts once they arrive, and then probably return or sell whichever one I like least. Or if they are both nice I'll keep them both, 'cause that's the cpf way.
I received my SC600 MK IV HI back in December. I love this light! Still using the default UI as it matches my SC32.
It would be pretty great if there was an option to turn off sub-level memory.It's still a pretty unique UI compared to other lights I own. I understand that some people set H2, M2 and L2 to all be the highest brightness setting, so they can double click from any level to get to turbo, solving (3) and now addressing (4) to an extent, although with sublevel mode memory, this wasn't a good solution for me, since I know I would forget to reset the sublevel before turning it off, thus negating any inherent predictability from how I set up the main levels.
Thanks for sharing this, WalkIntoTheLight. :thumbsup: I like your way of thinking.Try playing with the G6 and G7 groups, and set them up the way you like. I have a few older Zebralights, so I too want to keep the low-medium-high thing going so I don't get confused when using different lights. But, I use different systems for the G6 and G7 groups, depending on the light and the intended purpose.
For example, for a "bedside light" that I sometimes use the SC64w HI for, I set up a G7 group to be the following:
L2 - 0.06 lumens
M2 - 0.86 lumens
H2 - 2.3 lumens
The intent is that when I go to bed, I set the light so that when I do a long-press, I get a very low moonlight. But, if I'm half-asleep and screw up by either pressing too long or too short, I still get a very low mode so I don't blind myself with bright light. I could set all 3 modes to be 0.06 lumens, but I kind of like having slightly different levels even if they're all low.
As for H1, M1, and L1, I set them to modestly higher modes. Basically, levels I use indoors. So, G7 is my "indoor" mode group.
I set G6 as my "outdoor" mode group.
L2 - 7.9 lumens
M2 - 52.5 lumens
H2 - 245 lumens
Basically, those are the modes I use for walking around outdoors, giving me a good range from basic close illumination to a fairly bright level. Then I set up the other modes to be the following:
L1 - 1300 lumens
M1 - 1300 lumens
H1 - 1300 lumens
Yup, all max output. This allows me to double-click from any mode and instantly get turbo. I don't have to press&hold for a few seconds if I need max, I can get it right away.
You'll notice that the levels I normally use all have the traditional low-medium-high settings that older Zebras force you to use. But, I set them up for particular uses, indoors or outdoors.
Anyway, that's how I set my SC64w HI and SC600w IV HI up. I don't really use my SC600w HI indoors, but I set it up for consistency anyway.
The SC600w IV Plus I use on my bike is set up differently, but still similar to my outdoor group.
For new users programming G5 (standard Zebralight UI) can be a little difficult, but can be figured out in just a few minutes. The G6/G7 is. A little harder. I think they want to make it easier for people use to their old UI, and newcomers.
- G5 to behave the same way as G6 and G7 - why not?
That would be wild, 9 modes to choose from!
At that point, I reckon' a ramping UI would work better. But who knows.
I never got around to appreciating ramping UI's, I just love knowing the exact level I'm on hah.
Zebralight UI is really nice for me, but I would add shortcuts for momentary on and electronic lockout.
I'm with you -- I prefer a physical lockout. Many lights with them require just a very small turn of the tail cap to achieve it. No big deal at all. Electronic lockout is only necessary when physical lockout isn't possible (like with a body lacking a screw end cap).I'm not a fan of electronic lock-outs, because it's way easier to just slightly twist the tailcap for a lockout. But, they could make 5-clicks a "dummy" mode, where the light would only operate as a single-mode 50 lumen light, and automatically shut off after 1 hour. That way, you could enable dummy mode, and then hand the light to anyone. 50 lumens is bright enough for general-purpose use, and doesn't generate any heat if the light turns on in your pocket. A 1 hour shutoff would preserve the battery in case of accidental activation, or a dummy leaving the light on.
