Did you drop the light at all or expose it to any shock? If not, your cell may have just been a little longer then the tolerances allow(the tolerances are very tight unfortunately).
These new MKIV's are going to be better then the MKIII's due to the force being dispersed between more pins and around the perimeter of the terminal but, if a hard enough shock or drop happens they will still dent cells. My 64c dented a cell the other day when I dropped it on a hard surface but, up until that point the cells were fine.
These pogo pins just don't offer any give once fully compressed and the flat top cells positive terminals are pretty weak and prone to denting(unlike button tops which are much stronger). These lights will never protect batteries as well as a duel spring design will but, it is a trade off for a smaller light and easier tailcap installation and removal. It should also be noted that even many duel spring designs will dent flat top cells with enough shock. Malkoff's will dent flat top cells, for instance, if dropped hard enough.
The only thing you can really do if you want added protection is use an O-ring to help cushion the positive terminal. And, of course, don't drop the light if you can help it(I can't apparently and now my nice new light has a ding in it along with my brand new VTC6 lol
![Banghead :banghead: :banghead:](/styles/default/xenforo/smilies/2/banghead.gif)
