Guys -
I received 2 samples of the Fury today and just finished playing a bit. I'll offer the following comments for thought and discussion but please keep in mind this is my initial impression of the light after only a few minutes of use.
Tint on my sample is almost identical to the E2DL for those familiar. It's very white. There are colder beams out there but it certainly is not warm. I'm turned off by cold tints and this to my eyes just looks "white". I'll call it "clean white". The low output may be slightly green but it may be due partially to the eyes adjusting from a very intense bright light to a "utility" level of light. This mode is very useful for general tasking. It does seem to be slightly lower at its hotspot than my E2DL on low or my HDS set at 15 lumens. This is most likely due to its' good amount of spill. It's more like the E1B on low at its' hot spot but without the tunnel vision of the E1B / E2DL. It offers decent spill and I think it will be quite useful.
Regarding spill... its greater than the U2 and is very similar to the Malkoff M61. The beam diameter tracked very close to the M61 at least at the ranges that I observed. The output, however is much greater. With its generous spill, it threw further than the E2DL and M61. I want to put it head to head with the M6/MN21 soon, but I suspect it will throw beyond the MN21. Perhaps I can try that tomorrow night.
The light is very "pocket-able" and is basically the same length as the 6P. Build is what one would expect from Surefire, although the positive terminal of the battery will directly contact the board. My unit has the GLASS window in lieu of the Lexan / plastic window. Also, as a note to those whom like rechargeable, I slid an AW 17670 in for kicks and grins... both light levels fired up fine. High may have been slightly diminished but so close that I couldn't say for sure. Run time is unknown at this point but its something worth looking in too.
I did manage to take some pictures but have to get them resized and hosted. If time permits, I'll try to make that happen soon.
All in all... I think I'm going to like this light
