In the end it looks like before reaching steady state it is impotant to get the initial heat away from the LED quickly and transfering it to the whole body as quick as possible to avoid a heat-buildup right at the slug ... for example with a generous al heatsink with good and big contact area to the ti body.
Then we (or ... YOU :nana: ) would have to mke sure that the heat will be able to spread throughout the body quicker than the heat-buildup at the LED to avoid the magic smoke.
Only after that will the steady state be important and as a consequence, the heat removal from the light itself via air, hand, or whatever means.
So ... from my limited technical understanding it owuld seem that steady state thermodynamics are most certainly the most important factors in those lights, but we*'d have to make sure to be able to reach steady state at first.
bernie
bernie
