Stereodude
Is there somewhere I can buy a proper thickness metal shim that's the size of the metal slug under a SSC so that the emitter will be at the same height as a Luxeon? :thinking:
Thanks, now I just need to figure out how to compensate for the cost of the shipping. I like the washer idea.The Shoppe has them. Click here.![]()
Nope, just plain copper.Are they have any sort of plating to them? I don't like using epoxy to isolate the slugs.
Pennies have been made out of Zinc for many years...
I found some brass washers at a hardware store the right size. Not quite as good as solid copper- but worked fine for me. I believe the sandwich shoppe sells them?
That's not what I found when I ordered them. LINK
I had to sand them on both sides to get them flat and closer to spec.
-LT
I agree. Looks like they were made using a punch press. I used a 1" metal bar on a metal table to roll them, less sanding that way.
The specific heats of brass and copper are nearly the same, so brass is definitely as good an option as copper.
