I'm trying to find a driver that will power a Cree or SSC that will be fed by a common CR123a. It needs to be less than 17.3mm wide and well under 6mm thick including wiring/HS'ing/sealing to the emitter. Preferably running at ~800ma, preferably capable of ALSO handling 2 cells.
Some DX converters are around that size but don't meet all the criteria. Maybe the micropuck from LED Supply? FluPic is too expensive.
Edited to add: I no longer need more suggestions. Thank you for your time
