TallNHairyDave
Hi folks
I've modded a Thor X Colossus to a 35W HID, and while the mod was simple to do, I've hit a problem with the quality of light output...
In short, it's got the sort of bright flood that I'd expect to see (having seen photos of other people's modded Thor beamshots), but the small tight hotspot that is visible when I shine it on the ceiling at home (8 foot celing height) completely disappears when I do a horizontal beam test at some trees about 200 feet away. Definately NOT what I'd expect to see. There's only really a hotspot visible if you shine it at the ground up to maybe 20 or 30 feet away.
The beam pattern is more like the bad old maglite days with a big dim hole in the middle of the spill where there should be a nice hotspot, and this makes me think that it's probably bulb position in the reflector, but I thought I'd ask the experts for some advice.
The Thor's reflector takes H4 bulbs, and comparing the metal base on the original Phillips H4 bulb to the plastic(?) base on the HID bulb it's obvious that the HID isn't going to sit as far into the reflector as the Phillips.
The locating tabs on the H4 are metal and about 1mm thick, but the ones on the HID are closer to 3 or 4mm thick. I'm assuming that this means that the hot spot of the HID bulb is going to be at "not quite" the right point in the reflector for the reflector to give the proper beam pattern?
Would it be worth me trying filing down the lugs on the HID
so they are the same thickness as on the H4 bulb?
Thanks a million for any advice. :thanks:
Cheers
Dave
Cheers
Dave
