Thoughts on multistart threads
gadget_lover
Near Silicon Valley (too near)
Why would you want a multi-start thread?
I can think of several examples. You would want one when you need to move a nut a long way with each turn. The head of your mini-mag light is one such example. Another use for multi-start threads is when you might want to be able to quickly screw something together, like the cap on a water bottle or a fountain pen.
In the first example (long travel with each turn) you might ask "Why not just use a coarser thread?". The answer is simple. A coarse thread is a deeper thread. A 4 TPI thread is about 1/5 inch deep but a 16 TPI thread is just 1/20th of an inch deep. This is a major concern if you are working with a flashlight tube that has walls that are only 1/8 inch thick.
Can you even use a 4TPI thread on a 3/8 inch shaft? After all, the thread is .2165 deep. Let's do the math!
.375 shaft diameter minus .4330 (.216 off each side) and you end up with a negative number. Try the same with a 4 start lead 16 pitch and you have .375 minus .125 ( .0625 from each side) so there is still 1/4 inch of shaft left for your screw.
In the second example (quickly screwing something on) , having 3 threads ensures that wherever you start from, the threads will engage with a twist of the wrist. This is important because the wrist only rotates about 120 degrees, and fingertips add another 80 or so degrees of rotation. A standard thread will take up to one revolution to find the start of the thread, then at least one more to screw it on.
You can see an example of 'quick screw' in action on your water bottle, jelly jars, milk cartons and some flashlights.
In theory, it's complex. In reality, theory is often wrong.
The theory of a multi-start thread is fairly straightforward. Two or more parallel threads are cut with equal spacing. Because the threads are equally spaced the start of each thread will be evenly distributed too. A two start thread will have two threads that start on opposite sides of the work. A three start thread will have one starting every 120 degrees.
This is a good point to introduce a couple of terms. The LEAD is the number of turns per inch of a single thread, expressed in TPI. A nut will move 1/LEAD inches per turn.
Then there is PITCH, also expressed in TPI. The pitch is based on the distance from the center of one thread to the next. The depth of the thread is determined by the pitch.
A 2 start thread with a lead of 4 ( two 4 TPI threads that are interleaved ) will have a pitch of 8 TPI and the thread depth that is the same as a standard 8 TPI thread.
Your basic mini-mag uses a multistart thread to allow you to quickly focus it with only one hand.
The thread for the mini-mag head is 4 START, 20 TPI pitch, and 5 TPI lead. There is a new thread every 90 degrees, and the head moves 1/5th of an inch with each revolution. The threads are only .6 inches long, so 3 turns will unscrew the head all the way. It goes from totally focused to totally unfocused in less than a turn.
How do you make these magic things?
So how do you make these things? That's a good question. Most often, you single point thread them on a lathe. You can get multi start taps too, but we'll talk about using the lathe.
Obviously you will need to set up your change gears to cut the LEAD, and not the pitch. The major and minor diameters are based on the PITCH since the thread depth will be based on the pitch too. The puzzling part is how to cut the second thread (and subsequent threads) exactly between the path of the first thread.
When I first pondered the multi-start thread, the obvious solution was to use only the cross slide to provide the infeed while threading. That leaves the compound (set parallel to the work) so that I can move the tool over the exact distance of the pitch to pick up the second and third thread. The process is to cut one thread (multiple passes), then move the tool over exactly one pitch using the compound, cut second thread, repeat as necessary. It works, but many machinists hate losing that 29.5 degree infeed using the compound.
Wisdom of the ages
I found an old Popular Mechanics article on Google that talks about multi-start. See end of post for link. The 1947 article shows several popular methods.
The first method is to cut your first thread, then rotate the work 180 degrees in the chuck (or the dog if turning between centers). Then you can cut the second thread. This works but you can lose concentricity as the work has been remounted.
The second method is quite ingenious. It uses a property of the threading dial that did not occur to me before. The threading dial not only shows where to close the half-nuts so that the thread will start at the same spot every time, it also shows indirectly where the thread will start 90 and 180 degrees off.
Here's an example using the Threading Dial table for my 7x10 lathe to cut a 2 start, 12 TPI lead, 24 pitch thread.
First I set the change gears for 24 TPI. Then I check the threading chart for good starting points for a 12 TPI thread. It says 1.3.5.7 which means I can use any of 1, 3 , 5 or 7 and it will start at the same spot every time. I cut the thread as deep as needed for a 24 TPI thread using 1 ( it can be any odd number) on the thread dial because it's easy to remember.
Now it's time for the second thread. What to do?
Since I used odd numbers for the first one, I will use the thread dial number 2 because it is half way between two valid numbers for the first thread. This causes the new thread to be exactly 1/2 revolution off from the first one.
If I were doing a 4 start thread, I'd use the half numbers between the odds for the second, third and fourth threads. My leadscrew is 16 TPI, and while the threading dial has 8 positions marked the half-nuts will close at 16 spots.
Thread: dial
1 : 1
2 : 1.5
3 : 2
4 : 2.5
Another method mentioned in the article is the non intuitive use of taps to cut multi-start threads. The trick is to use it as a multi point tool. You again set the change gears for your desired LEAD, but you use a tap with the desired PITCH. The the tap is mounted parallel to the work and the cutting edge of the tap is centered at the normal tool height. You then cut the threads like you were using a single point tool. You use the threading dial for the LEAD in this use, not the pitch.
Example, an external 2 start 24 TPI pitch with 12 TPI lead: Use a 24 tpi tap (any diameter) with change gears set for 12 TPI. Use the threding dial settings of 1, 3 , 5 or 7 (on my lathe) and the depth for a 24 TPI thread.
A good write-up from 1947 is here:
http://books.google.com/books?id=z94DAAAAMBAJ&pg=PA222&dq=multiple+threads&as_pt=MAGAZINES
Daniel
Thank you for the write up Daniel! Definitely something I want to learn.
I have a MagAA to MagC head adapter. I know it was made on a CNC but I've always wondered how it could be made on a conventional lathe.
The MagAA to Mag C head was one of the projects I did that really needed the multi-start threads. It came out OK, but what I ended up doing was to make a delrin sleeve that was threaded for the C head and bored for a tight fit to the Mag AA body. I then cross drilled the sleeve for a delrin setscrew. The setscrew deformed and I ended up with 1 tooth in the thread. As long as I was gentle it worked fine.
It would be fun to remake that piece in aluminum with proper threads. Maybe shoot some pictures this time.
Dan
I just verified that a 5 TPI lead can be set up on the 7x12. The gears are a=80, b=50, c=80, b=40 .
That means the C to minimag adapter can be properly threaded on the 7x10. :)
Daniel
Awesome write-up. I'm using a 4:1 multistart lead screw (pre-made) on a mechanical positioner. It's very useful for traveling distances quickly when doing motion control.
Great write up - thanks for a very detailed explanation of the process.
Many consumer items use a variation called an "interrupted thread", brought out during the mid 1800's for use on breech loading cannon. Photo shows neck finish on a 2L Coca-Cola bottle:
Even though the idea had been used on artillery for 150 years it was patented for plastic bottles in 1990 (US Patent 4948001). Surprisingly the reason for using the interrupted thread on a plastic bottle is not for ease of closure but rather for strength. Here's what the patent says:
It has been found that in the blow molding of the threads, there is a thinning of the wall of the neck finish at the roots of the threads and under certain circumstances, when a closure is applied at a high torque, there is an axial collapse of the neck finish rendering the container unfit for use. The problem of axial collapse of the neck finish is overcome by interrupting the threads so as to provide axial beam strength at circumferential intervals around the neck finish.
I think that the interrupted thread on that particular bottle is for ease of molding and strength of the bottle, or even saving plastic, but not necessarily for quick closure. In order to be quick closure i think the cap could have only a few ( 4 per thread in this case?) lugs that enter those gaps and engage the threads. I would think it would be weird to push the cap on and then only give it 1/8 inch turn. What kind of thread is on that bottle's cap?
The stepped interrupted thread on the cannon breech is ingenious. http://en.wikipedia.org/wiki/Welin_breech_block It gets around the fact that an interrupted thread needs to have a complementary area on the mating part that has no threads at all.
My latest murphy's law tale: While testing the gear train to cut a 5 tpi lead on my 7x12 lathe I did not fully engage the forward/reverse tumbler. I was running it back and forth, verifying that the threading dial would give me a correct start each time if I started on "2". It ate the nylon "pinion" gear. Little nylon teeth popped off, fouling the other gear on the tumbler and breaking a tooth there too. New ones from LMS will be here Wednesday. Sigh.
Daniel
Daniel
Oh man, that sucks! Do they make a metal gear set for the 7X? Or can the gears from the 8X work?
... It ate the nylon "pinion" gear. Little nylon teeth popped off, fouling the other gear on the tumbler and breaking a tooth there too. New ones from LMS will be here Wednesday. Sigh.
Daniel
I stripped the 80 tooth gear a few times, now, when I order, I get a spare as well.
The trashed gears are just a minor bump in the road. New ones are on the way and I can still use it in the mean time. Just can't thread. I figured I was lucky to get 6 years out of them. They are considered sacrificial since they will tear apart before the change gears do.
Yes, it's been almost exactly 6 years since I got my 7x12. :) Dec 17, 2005
( http://www.candlepowerforums.com/vb/showthread.php?101645-Lathe-upgrade-the-hard-way )
I bought spares as well. I figure that now that I've figured out how to trash it I do it again. :) While I could get metal replacements I'd rather let them break when necessary.
Daniel
So I gave this a try today....MagAA thread.
Turned to diameter & length. Normally I don't cut a thread relief unless an oring will be directly behind the thread but at 5 TPI I figure the leadscrew will be turning pretty fast.
Then I marked the threading dial.
Cut the first thread, verified 5 TPI. Cut the second thread, crap, the threads weren't lining up. Then I remembered I was cutting 5 TPI (duh), not an even number thread like I'm used to, & was read the dial wrong. Ok, so I don't need the marks. Let's try again....
Second thread (forgot to take a pic of the first thread).
Third thread.
Fourth thread.
Threaded to the same pitch diameter as the MagAA.
Success.
Had to thread at 65 rpm though. Threading dial was moving way too fast than I'm used at 180 rpm & set for 5 TPI.
Thanks again Daniel for posting this thread. :thumbsup:
Do they make small multi start thread taps, like in the 5/16" or 3/8" range?
My pleasure Will. The subject is one that puzzled me for a while. I figured it was worth writing up once I finally got it to work consistently.
If you did not use the marks on the thread dial, what did you use?
Daniel
Daniel
Oh, I did use the marks on the dial, just did not have to use half marks. Last night I was looking over the informative Google link you posted. However the error on my part today was that I did not realize I was cutting an odd number thread (probably by habit). Most odd number threads on my lathe are used with 1 & 5. So I only needed to use the marks that are already on the dial.
OK. That's what I had guessed that you meant, but I was wondering if you'd used one of the other techniques.
Those threads came out great, BTW. Nice work. Next will be the AA to C head adapter? :) I've always been amazed at the throw you get from that combination.
Daniel
Thank you Daniel. :)
I originally wanted to use the method with the compound set at 90° (parallel with the spindle) & using it to advance to the next thread lead, thought that would be easiest. But then I thought it would be best to use the thread dial if possible & as I like to thread with the modified flank method as you mentioned. And once you figure out the thread dial for whatever lathe is used (assuming it works for the multi-start thread your looking to cut), I think that's the easiest & best method. Luckily it only took me one mistake to get figure it out.
I haven't played with Mags in a while so not sure if I will make a MagAA to MagC adapter anytime soon. But I have always wanted one that followed the taper of the MagC head to meet with the MagAA body. The one I have is very nice but it looks akward (not that the big head doesn't already). It has just been sitting here on my desk for the past years. Also thinking about making a copy of the MagAA host in Ti just to have. Thanks to you I now know I can make one.
Here are pics of a mod I did a while back for someone & I used the setup for testing. The work performed was on the module, the host is mine. I agree, I also love the performance.
(Would look much better if the flat edge was filled after the head, possibly add another fin or two there on the adapter)
Awesome Job Will......those look nice. On my lathe I just tell it 1-10 starts :)
Mac
